Walls of Manufactured Stone
0 Members and 1 Guest are viewing this topic. Read 1439 times.
Doublej
« on: 14 May 2014, 02:42 am »
I need to replace a long low retaining wall currently made with now rotting landscape timbers. It's about 60 feet long and varies in height from 6 inches to approximately 3 feet.
I am contemplating upgrading to some sort of fabricated stone. Unilock and Versalok are two names I have come across. Has anyone worked with these or similar product products? Are they cheaper and/or better than real using real stone or cinder block?
Even though it's a low wall, I'd have the work done by a professional.
TomS
Re: Walls of Manufactured Stone
« Reply #1 on: 14 May 2014, 02:59 am »
It really depends on whether the manufacturers have a plant around you for distribution. I've used Allen Block with great success, which is widely available close to us in Indiana, Ohio, Michigan areas though they're based out of Minnesota.
http://www.allanblock.com/
Doublej
« Reply #2 on: 2 Jul 2014, 01:20 am »
Thanks TomS.
The contractor doing the work for me is going to installed the straight faced product from the link below.
http://www.idealblock.com/product-details/items/stonewall-collection.html
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« Reply #3 on: 2 Jul 2014, 03:35 am »
... nevermind, didn't read your original post well enough  :duh:
Bizarroterl
« Reply #4 on: 2 Jul 2014, 05:36 pm »
If you're paying someone to install, the manufactured stone will be the least expensive.    No matter what way you go do your research on what should be done before the wall is stacked.  A proper footing is the difference between a 50 year install and a 2-3 year install.
