0 Members and 1 Guest are viewing this topic. Read 23573 times.
If you like the sound, why not repair the CJ? It will be cheaper and you won't have to guess whether the others will give you the same type of sound.
I recently updated by USB DACs to Wavelength Audio. I now have a Brick in my main system and the Proton in my office headphone rig and I love the sound from both of these. Recommended devices to audition.
Oh Yeah, how could I forget those sexy BMC chassis and sleek looking Chord. Did you or do you own one of those dac that you are mention above? BMC dac sure match my deco style perfectly. ThanksAustin
I own the Qute HD and Lampi L4.I have a UK buddy with the L5 and the BMC as a backup Dac. Hwe had a Vega and sent it back after 2 weeks. Not his sound.
What a surprise today, I found a lost treasure. I took my 15 years old CJ DA3 out of my clothes. Hook it up and Whoa.!!!! It sounds very good after 13 years sleeping in the box. I can not say it trumps my Oppo 105 but it take me to a very different path of music reproduction. Despite some noise I got as first start up and a bit distortion at 0° phase position. Also sound output is low, it is back to normal operation now. No noise and gain seems to be stable. With 180° phase position (I prefer this mode in my system) The sound is very pleasing. Tight and tuneful bass, nice and warm midrange and a bit lay back or roll off on top. Very CJ, very tubey feeling, very analog. I will give it a try over the weekend. I suspect sound will improve if I have a better digital cable on hand. Right now I am using cheapy $10 Belkin optical that I find in my junk cables box. Never know what you will find under your pillow. At this point, I like what I am hearing now. I can feel the Oppo got more punch and openness. Stay tune, there will be good old technology dac vs state of the art modern dac report.Austin
What BAT preamp is that on the bottom? I have a VK-51se
I reviewed the PureDac recently for Dagogo and don't think it may be the right piece for you, based on your sound preference in your original post. But if you can audition one you should, it may match if you have a warm sounding system.
It is Bat Vk32se. It replaced the Vk31 and lead my system to a whole new level.
Thanks, really appreciated. So what dac in your mind that would fit my system well? Austin
I have a Bat 32SE. Have you thought about upgrading to the 33SE? Are you using NOS tubes?
I think a non-oversampling DAC or a tube based one will probably provide what you're trying to achieve.
Thanks all for your input and comment. While certainly, the Vega and Lampi L4G4 got high praise here and everywhere, i think as of now, I would not buy them due to several reason.1. All my music is 16/44 flac. So I am unable to take advantage of those superior high rez processing. 2. I would not buy into higher rez format anytime soon. Vinyl is my highest rez.3. My main focus, my goal now is improve my digital front end to make the most out of those cp ripped flac files.I have audition several dac lately. Most of then sound wonderful with high rez but fair out average with red book format.( Surprisingly, Some of the most respectful modern dac could not keep up with older dac from the golden age on this format). I think I found what I am looking for at the price that I can live with. It is a used Conrad Johnson HD3. To my ears, this is one of the best usb dac that do red book format justice. Isn't it crazy to spend money on a usb dac which only has one usb input and max out at 24/96 now. In my case, i said it worth it. It is what I am looking for - Warm seductive midrange, textures, and fuller body and authority control in lower region.
I think the Vega sounds incredible with redbook, which is 90%+ what I've demoed it with. Yeah, it does sound even better with Hi Rez and DSD, but if redbook didn't sound great, I wouldn't consider it. Glad to hear the CJ DAC works for you. I have CJ preamp + amp, so it would be interesting to here the HD3. You don't see many reviews around, so getting your listening impressions, particularly vs your older CJ DAC, would be valuable.
