0 Members and 1 Guest are viewing this topic. Read 18656 times.
Wow, what a room!How much is one room per night, off-season, Queen or King, non-smoking?
All of the art in the room is either based on Fantasy, SiFi, or Magic.
I was also rereading the thread, hoping to read some updates on the speaker positioning process, but I guess it must be close enough!
I'll try that with my SPL meter but I fear it may also be affected by traffic noise (early in the morning is better but still not quiet according to the microphone).Maybe my ears will be good enough.
One thing I noticed was that if I dip my ears down - i.e. point my head down as if looking at the carpet say - I get a more open, detailed sound. It's rather like putting your hands behind your ears or pushing your ears forward, but better. This is not the same as moving my head forward, or my chair forward, neither of which make such a difference.
For the 42/43Hz boom I've adjusted my Behringer DEQ2496, Parametric EQ. The nearest I can get is 44.3Hz but using a narrow band (1/6) and -6dB seems to have had an effect in reducing the boominess.
I addressed this several years ago in listening observations.Not sure if it is the same with everyone, or with a limited population.It seems that the pinna shape and collective ability is such that you hear with slightly more acuity with your head down.That said, if you are listening to RM40s, part of that may be due to getting down closer to the dispersion plane of the Tweeter.
I prefer to manually take care of such issues as well. My modded DCX does a fine job of it, but I have been looking into those DEQX units, especially their top line preamp.
My new treatments have been built and installed. The measured response is better across the entire lower frequency bands allowing me reduce my EQ corrections and the dip at 80 Hz has filled in a bit, but not as much as I had hoped for. However, my listening impressions have been very favorable with these new improvements, more so than the new measurements might suggest.
I'm pleased for you. It must be very satisfying after all your efforts. I'd love to be able to ditch my equaliser mainly out of principle, but also so I could connect my DAC and Transport in a better way. However EQ is still essential for me and makes clear improvements. Yet again it is shown that listening is the ultimate test and measurements are there to guide us. It's too easy to get carried away with measurements alone.
Congrats on the new audio room, it's beautiful, it makes my dedicated audio room look like a toilet… LOLI hope you have many years of musical enjoyment with it, I don’t think that will be to hard to do.
The Real Traps test tones are a great tool and I do use them to more closely map my room and verify against my software measurements using True RTA. It's resolution only goes to 1/64.Generally what I do is play the tones my measurements told me I have issues with. For example: My previous room had a deep suck-out around 47Hz. True RTA can play any constant tone needed and so I put on 47Hz and walked around the room with my RadioShack db meter (be sure to use the off set calibrations) to find out where a build-up at 47Hz was located. My thought being that if I can reduce where that frequency is peaking it will also allow the dip to naturally fill in. The build-up was located in the center of my front wall from floor to ceiling and so I constructed a large bass trap in that area of simple OC 703 with a decorative cover made of cheap oriental screens:It worked pretty well. That dip did fill in a good bit and since is was a broadband type of trap, it also helped to smooth out other frequencies as well. That is why I am a fan of the broadband approach to bass treatments. This time around I am getting a strong build-up of 80Hz in my front two corners, as well as the fifth corner created in the original part of my room from the expansion. I ordered up the material today from GIK and plan to do build up one corner at a time and see what happens. It may not do everything that I want this time, but I am sure it will be of benefit one way or the other. The room is large enough where I don't think this will harm my higher frequencies, but if I feel it does I can make these traps reflective of those.
