My A/V-3 (work in progress)
0 Members and 1 Guest are viewing this topic. Read 5433 times.
Hackenbeck
Re: My A/V-3 (work in progress)
« Reply #20 on: 20 Apr 2014, 12:25 am »
Just beautiful. A tip for the LP storage: If you have a small local record store that sells new LP's, in the cartons the records are shipped in will be a couple of 12" X 12" pieces of cardboard. Ask them if they wouldn't mind saving them for you to pick up once a week (shipments usually arrive on Monday, as new release day is Tuesday). Use the cardboard to fill the empty space in each section of your LP bookcase (until you buy more LP's, and fill them that way!). If left at too much of an angle for too long, LP's warp.
Thanks for the tip, I'll check it out!
mlundy57
« Reply #21 on: 20 Apr 2014, 01:01 am »
Very nice indeed. How did you make and mount the black baffle?
Mike
Hackenbeck
« Reply #22 on: 20 Apr 2014, 03:43 am »
It is simply another piece of mdf that I cut, shaped and painted black. It's simply glued on with wood glue and I inserted magnets in the four corners in case I wanted to make a grill for it later on.
