0 Members and 1 Guest are viewing this topic. Read 21869 times.
I'll be a bit more clear. He's never had a 300B fail in 12 years, but he has rolled various 300B's thru the years. So it's not like he's had the same pair in service for 12 years. I believe he's tried 5 or 6 different manufacturers. The best (and most pricey) of the bunch has been his current Emission Labs. They've been in the amps for about a year.
FRM,I think you are confusing two very different things. One is the ability of the amp to drive a low sensitivity. Obviously a low watt amp won't do a good job here. That is a completely different issue than "stressing" a tube and shortening its lifespan. Lifespan is a function of, aside from quality control and design issues, of bias current. Meaning how hard you run the tubes in the amp. With all due respect, that is no fairly tale, its simple physics.
Were you asking me or FRM?The part that I am not 100% clear on the effects on the output tube is how clipping (say hard clipping) of the amp effects the tube's characteristics via secondary effects (via caps, resistors, etc). This isn't very clear cut. But in class A the tube can source X amount of current at Y amount of voltage based on the operating point, asked more and the tube compresses but doesn't source any more (except maybe to steal from the driver stage ala A2 operation, so it isn't really doing anymore work beyond what it can do.
Most or all small tube amps builders recommed use its amps with hi sensitivity loudspeakers.Its much more easy to the amps.
I think that spec is given to best showoff the meagerly-powered amp's capabilities without clipping. No manufacturer of a 3 watt amp is going to recommend 84dB speakers because those insensitive speakers will clearly show the amps limitations. I've never heard tube life given as a reason to use high efficiency speakers.
I'd imagine if you looked at recommeded bias current setting for similar amps, it is going to give you some idea of how hard an amp is pushing its tubes. If you take 2 amps using the same tube, and one is bias'd at a current 25% higher , I'd think it would have an effect on the tube life.If I'm understanding what others are saying about high bias current....-jay
