Spike size
0 Members and 1 Guest are viewing this topic. Read 2438 times.
skenderbeu
Spike size
« on: 24 Mar 2014, 07:18 pm »
What size are the spikes of the  Super V ? M8 or M6?
thank you
Danny Richie
Re: Spike size
« Reply #1 on: 25 Mar 2014, 02:48 pm »
It is a metric thread. I don't know what size exactly. I have installed hundreds of them and never needed to know. Thread diameter is .31".
jtwrace
    • TIPP YouTube Channel
Re: Spike size
« Reply #2 on: 25 Mar 2014, 02:57 pm »
If that is the OD of the spike it is more than likely an 8mm.
Danny Richie
Re: Spike size
« Reply #3 on: 25 Mar 2014, 03:02 pm »
Yeah, OD of the threads.
Many years ago I went down to the hardware store with one of the spikes and picked up a few metric bolts that matched the thread. I still use one of those bolts for installing the inserts. I have never really paid much attention to what size they were and it's been many years.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
Re: Spike size
« Reply #4 on: 25 Mar 2014, 03:45 pm »
Likely M8x1.00 - diameter and pitch
persisting1
Re: Spike size
« Reply #5 on: 25 Mar 2014, 08:48 pm »
If they are the same as the ones Danny sells on his site, they are M8. I just bought a set.
« Last Edit: 26 Mar 2014, 06:52 am by persisting1 »
bdp24
Re: Spike size
« Reply #6 on: 26 Mar 2014, 05:25 am »
I think M8's have 1.25 pitch, and M6's 1.00
persisting1
Re: Spike size
« Reply #7 on: 26 Mar 2014, 06:52 am »
The thread i needed was 8mm. Danny's spikes fit perfectly. 8mm thread is not common for spikes. I was pleasantly surprised Danny had these in stock. You can easily spend a ridiculous amount on spikes at this measurement. I'm very happy with this purchase.
Millicent Bystander
Re: Spike size
« Reply #8 on: 28 Mar 2014, 03:04 pm »
Deviating from the subject slightly...
I have built 40lb stands for my X-LS's. What is the best combination? (A1 & B2?):
A) Speaker enclosure and stand interface = 1.Spikes / 2.Rubber feet / 3.Cork / 4.Felt / 5.Something else
B) 40lb stand and wooden floor interface = 1.Spikes / 2.Rubber feet / 3.Cork / 4.Felt / 5.Something else
bdp24
Re: Spike size
« Reply #9 on: 28 Mar 2014, 03:25 pm »
Blutak?
Millicent Bystander
Re: Spike size
« Reply #10 on: 28 Mar 2014, 03:27 pm »
Blutak?
For both interfaces?
(Love that low tech idea BTW)
Danny Richie
Re: Spike size
« Reply #11 on: 28 Mar 2014, 03:45 pm »
I go with A2 because I am always swapping out various speakers on the stands and the rubber dots do not harm the bottom of the speakers. A spike would be better though technically.
I go with B1 to focus the weight down to small points. This helps couple the speaker to the floor. I also use brass disks under the spikes to protect the floor.
Millicent Bystander
Re: Spike size
« Reply #12 on: 28 Mar 2014, 03:57 pm »
Thanks Danny
Thats exactly the info I was looking for. Have you experimented with different rubber dots? Any recommendations?
Danny Richie
Re: Spike size
« Reply #13 on: 29 Mar 2014, 12:02 am »
Thanks Danny
I haven't played with them enough to say one is better than another.
