0 Members and 1 Guest are viewing this topic. Read 10035 times.
the bandwidth restrictions inherent in the design, not after hearing what amps that go beyond 80kHz sound like
Did anyone else notice that the Soundstage amp tests were from2001? As several people have noted there are several D amps that go out beyond 20k.
Again, he's talking about an 80hz limit, not 20:To me it sounds like a promotion for the DAC as much as news on the amp...
Ha!The TPA3116 with corrected filters might achieve 80khz. It does produce out to 100khz, but suffers from some phase shifting with at least stock filters. On a T.I. questionnaire 40khz is said pretty easy to achieve by filter change. It's not as high power as the ncores. But the point being is class D isn't going to be limited forever.
He said in an earlier blog entry that he thought the ncores were amazing but too costly for them to use for their "ultimate amp". He said they thought they could get nearly there for much less with the UcD. Obviously, he is building to a price point despite his later claims to be building the best amp possible. It's all there in his blog entries.
