If it ain't fixed, don't break it?
0 Members and 1 Guest are viewing this topic. Read 1739 times.
fado
« on: 11 Mar 2014, 03:51 am »
This is an old GZ34 used in my Modwright LS100. The glass part does not deflect noticeably in the metal base along the vertical axis but does rotate in the metal base slightly ~ <1mm. Is it better to leave it alone and just be very careful with it or is better to try a fix? If so, what are appropriate repair/stabilization approaches?
JakeJ
Re: If it ain't fixed, don't break it?
« Reply #1 on: 11 Mar 2014, 05:06 am »
If the glass envelope and its vacuum is intact and there is no gas then I say stick to your title for advice.
That's my .02.
Ericus Rex
« Reply #2 on: 11 Mar 2014, 11:00 am »
+1
JohnR
« Reply #3 on: 11 Mar 2014, 11:41 am »
Not that I've tried it, but a drop of epxoy may help stabilze it. If it's in an amp, just leave it there.
JakeJ
« Reply #4 on: 11 Mar 2014, 04:28 pm »
If you do try the glue repair be sure to use one that is high temperature resistant.  Gorilla Glue claims it is but I could not find any numbers to confirm how high.
fado
« Reply #5 on: 11 Mar 2014, 05:00 pm »
Thank you for the advice so far. My tube knowledge vacuum probably exceeds that of the tubes themselves.
This tube is used in a preamplifier and is functional, but what indicators mark vacuum and gas problems?
Alberto DeRoma
  • Delicious Sound Hound
    • Delicious Decibels
« Reply #6 on: 11 Mar 2014, 05:05 pm »
If it's working well, I would definitely, 100%, no questions ... leave it alone.
Alberto
JakeJ
« Reply #7 on: 11 Mar 2014, 06:31 pm »
Break down of the vacuum allows gas (air) inside.  The primary visible sign is the flashing (silvery coating inside the glass) turns white.  The best way to find out if it is getting gassy is to test it on tube tester that can test for gas.
Check out this YouTube video
https://www.youtube.com/watch?v=sn2YIynXbzY
