All,
Since mid last week I've been sick, sick, sick.
It started out as a lot of the flu-like symptoms, and then worked its way into a respiratory infection / sinus infection. I've been laid out in bed for a few days and still fighting this off. Tomorrow I hope to get to a doctor and get some meds to kill this off. I should be back to work again on Tuesday, but in the meantime I'll try to catch up with emails and the forum when I can.
Hi Vinnie. I think 1TB is the limit for now in 2.5 . Samsung has launched a 1.6TB enterprise drive, might be OEM only for now. Not readily available. But we may see 2TB ssds in 2.5 before the end of the year.
Hi Christopher,
Thanks for the info. At least we know that the drive can be swapped, upgraded, replaced when the time comes, etc. The 1TB SSD drive has been nice in there, but I haven't done much listening since I installed it.
Hi Steve in NJ,
Let's hope they are not too expensive when the come out! In time, I'm sure they'll get much cheaper...
I'm sure we can also substitute a 3.5" or 1.8" drive in there if 2.5" has limited SSD options. It's a SATA interface and not some proprietary interface thank goodness.
Can the z1 be setup to run on 220v/50cycles? Or would we need to wait for the level 3 mod to allow that (assuming we buy a unit for modding in the US)?
Hi Firedog,
There is no way to internally configure the Z1ES to run on 220V. The transformers cannot be rewired either. They do make a 220V version, but if this is something that you'd want to buy in the USA to have modded, then you are better off going with the 120Vac version and using an external step-down transformer (rated for 60W or more). I'd go 100W.
Here is an example:
http://www.amazon.com/Philmore-Heavy-Stepup-Stepdown-Transformer/dp/B000PCCABU$20 + shipping, and I'm sure you can find them all over. Do a search for "ST-100" step down transformer. They also make an ST-200 (200W version) and beyond.
The RWA-Z1ES-3 will not be a full battery conversion. There will still be a few sections of the unit that will be powered from the mains.
Speaking of the RWA-Z1ES-3:
While lying in bed staring at the ceiling this afternoon, it dawned on me that the LiFePO4 battery power for the RWA-Z1ES-3 can be installed
INSIDE the Z1ES! The transformer used for the analog power supply section will no longer be needed and can be removed, making room for the battery pack. The stock analog supply board could also be removed, as it will be replaced with discrete super regulator boards that I plan to hard wire to the Audio board to make the power feeds as short and clean as possible. In the stock configuration, the wiring is "ok" but can be cleaner, as the internal pics reveal.
I'm also thinking that the charger for the battery does not need to be very large, and it could reside inside the unit as well. I'll be aiming for >10 hours of play time in pure battery mode, but I am going to also include a switch on the rear panel to allow the user to select between pure battery mode and "AC" mode where the battery is charging and providing power at the same time (higher charge current to the battery than the load current that the battery is supplying, of course). So if your Z1ES will be on for a long time as you transfer GB's of music onto it, or if you like to leave your equipment on 24/7 because you swear it sounds better, you can do that.
When you are doing critical listening, you can easily switch to pure battery mode and should be able to get > 10 hours of listening. And when you power down the unit, it will automatically charge the battery.
This way, the user doesn't have to think much about the battery at all. You just power it ON/OFF like you normally do and enjoy it.
No external box, no separate power cable, no umbilical, no added connectors... NO ADDED COMPLEXITY. So, there is still much work to be done than simply daydreaming in bed, but it's a start.
As always, thanks for all your interest!
Vinnie
