Thanks , Vinnie. Will much appreciate if you could confirm actual value of output impedance in final product. Intended use would be for a bi-amp configuration using a Passive Line Level X-Over, where, as you know, actual values of impedances at I/O's are important for correct implementation.
Hi Mario,
- I tested it with the stock JJ E88CC tube.
Output impedance is a low 180 ohms (0.18k). You should get fine results driving any load >5k.
- I also tested a JJ ECC83 (12AX7) and the output impedance was ~ 700 ohms (0.7k)... still under 1k and that would be fine driving any load >10k.
Vinnie, thanks for the update - I must have missed that info for the output impedance, I am sorry!
But I am happy the tubes can drive 10K Ohm without a problem and with the integrated volume pot this means one pre-amp unit less in the signal path.
Hi Ivo,
No problem - it's a fairly dense thread already, so some things are probably going to need to be repeated here and there.
Some did email me about installing the Isabella R.E. preamp board on the back panel... you sick and twisted individual you! I love it!
Vinnie
"What are the implications of doing this?"
Hi finsup,
I haven't really looked much into it, and it is probably too early for me to get into, but I will take a shot at explaining it:
For someone who only needs single-ended RCA outputs, there is enough space on the HAP-Z1ES's rear panel to fit the Isabella Renaissance Edition board. This would allow for 2 sets of RCA
inputs (e.g. for a Phonostage, or other analog sources), 2 sets of volume controlled RCA
outputs, and a 0/12dB
gain switch. I would think that 0dB would be fine for most (preserving the ~ 2Vrms output voltage), but 12dB could be welcome with power amps with less gain, or when a low output phonostage is connected.
Why would one want to use the Isabella board instead of the tube buffers already posted above?- I'm not going to lie - the Isabella preamp board is even better sounding!
- Can accept 6H30s as well as 6922's (BUT DOES NOT ACCPET 12AX7, sorry).
- Already has RCA inputs that can be switched (relay controlled on the actual preamp board) - so only an input select switch that controls the relays would be needed to select the Sony's output stage, or one of the other 2 analog inputs.
- It would also mean adding a remote volume control, and you essentially get a modded Z1ES with built-in preamplifier, all rear-mounted for very clean layout. No need for interconnects to pass to another preamp.
- Could be powered by an external Black Lightning LiFePO4 battery power supply for the ultimate results
, or we can power from an internal mounted linear power supply like we are doing with the RWA-Z1ES-1.
- Will be less expensive than buying a separate Isabella preamplifier.
The part that still would need to be figured out is the remote volume control (I'd want it to work with the Sony remote and iPad/iPhone/Android App), and the input select switch (it would be much easier to put it on the rear, but if it needs to be on the front, it might require drilling the enclosure and I'm not sure how equipped I am for doing that
With regards to the volume control option, I was thinking that it would
only be controlled via the Sony remote or the App, but every time you turn it OFF it would bring the volume down to MIN (so you always know it is muted when you start listening and then you set the level). I could also more easily put the actual volume knob on the back (for those who require a physical knob to turn), but I don't see that it is that necessary.
So there you have it - the crazy idea that could be insanely good!
It would mostly appeal to those who want a built-in preamp. But it could actually be used without a volume control (fixed outputs) and we still can allow for an analog input or two.
I wanted to let you all know what is possible, even if these ideas are outside the RWA-Z1ES-1 / 2 / 3 modifications. They could still very well be excellent options to offer. One can pick the mod package that best suites their needs and budget.
Let me know what YOU guys think.
Vinnie
