0 Members and 1 Guest are viewing this topic. Read 45263 times.
Jim, does the mPad do the tagging or something else?
Let meKnow how that works for you. I've considered that same solution. I've also considered a roku that is strictly used for audio. I believe it's the roku 2 that would work using the app to control it. But I'm definitely interested in the salk streaming player if the rest of my music library. Sounds like an easy solution
This has aways been a bit of a mystery but I Have also ripped all my Cd's to Flac using Media Monkey for use sometime in the future.I would need NAS (don't want to use the PC) Stream Player, DAC & some control app to send music from the NAS to the Stream Player. I don't use Apple so is there any other App? Can the Stream Player be 230v.
I can't be sure, but it looks like a 4TB Sd card in there....yahoo. This product fits the bill.
Today I tried spotify using airplay, into my preamp and it sounded aweful, as expected. For me this still might work for my application. I would only use spotify to listen to new music to assist me with deciding whether I want to purchase the cd or not. It's better than the 15-30 second clip on Amazon. That's were I buy most of my CDs. Let me know if you come up with a better solution.
I hope one of those two USB is the output…….Why two ethernet ports? Is one an output?It is an attractive unit.
