SOLD: Jolida JD102CRC Integrated Tube Amp - Factory Modded - Reduced to $640
0 Members and 1 Guest are viewing this topic. Read 3266 times.
MarkR7
SOLD...
I'm offering up a factory modded Jolida JD102CRC integrated tubed amp, which is significantly better than the stock version that currently sells for $875. The amp is about a year old, and is in excellent cosmetic condition, and functions (and sounds) perfectly. Any blemishes you see in the picks are only photo artifacts or dust. I don't see any scratches, dents, or other defects on the amp.
It is very easy to bias, has excellent iron, and it sounds wonderful with the provided tubes (two quads of EL-84s, and the three input tubes). It sounds even better with a quad of Genalex Gold Lion EL-84s (which I don't have anymore).  I am most amazed at how extremely quiet it sounds (with respect to noise and hum) with my 98db speakers (Tekton Lores, also for sale in anther ad).  This is a very musical amp that really surprised me with it's audio quality.  This is coming from a guy who is used to SET amps! It's an unbelievable value, and would be right at home whether it's in your main system or in a secondary system.
I have unexpected bills to pay off from a hospital visit back in September, which is the only reason I am selling the amp.
The factory mods added over $300 to the cost:
The mod consisted of upgrading the signal path by incorporating 6 Jupiter Beeswax capacitors, and premium Takman Japanese resistors.
Features:
Fully Integrated Stereo Amplifier: Input 600mV driving 20 watts, maximum 25 watts output
Four Analog Inputs With Chassis Mount Gold-Plated RCAs
Custom Wound Audio Transformers with a core of German grain oriented silicon steel
Gold-Plated Binding Posts With Both 4 ohm & 8 ohm taps
Top Panel Bias Testing Terminals with Bias Adjustment Controls.
Blue Alps potentiometer, High-Resolution Caps & Resistors
Remote Control for Volume / Muting
Specs:
Maximum power Output: 25 WPC @ 8 ohms (1KHz)
Rated Power Output: 20 WPC @ 8 ohms (26Hz to 50KHz)
Frequency Response: 7Hz to 95KHz + 1dB; 0dB at 1KHz
Bandwidth: 14Hz to 80KHz + 3dB; 0dB = 20 W 1KHz @ 8 ohms
Distortion THD + N: Less than 1% at 20W output, 39Hz to 10KHz, 8 ohms
Circuit Type: Ultra Linear, Class AB1
Input Impedance: ≤ 250Kohms
Input Sensitivity: Max. 600mV for 20 watt output at 1KHz
Output Impedance: 4 ohms and 8 ohms
Negative Feedback: Less than 7 dB
Signal & Noise Ratio S/N: 70dB below rated output from 10Hz to 200Khz
Tube Complement:
Qty 4 EL84 (2x Matched Pair)
Qty 1 12AX7A Pre-amp
Qty 2 12AT7 driver tubes
Power Requirements: 110V-120 VAC 60Hz
Power Consumption: 90 watts standby, 200 watts maximum
Dimensions (HWD): 5"x12x8
Weight: 18 pounds
Buyer is responsible for paypal and shipping charges. Local pickup is welcomed.  I am 45minutes west of Portland, ME.
Websites for Reviews:
http://www.petery-hedden.com/jolida-audio-equipment/jolida-reviews/jolida-jd102crc-review/
http://www.enjoythemusic.com/magazine/equipment/1106/jolida_jd102b.htm
http://www.audioreview.com/cat/amplification/integrated-amplifiers/jolida/jd-102b/prd_322081_2717crx.aspx
Includes original box, manual, cord, remote, and tubes.
« Last Edit: 9 Apr 2014, 05:35 pm by MarkR7 »
Ericus Rex
You may consider reading AC's policy on bumping:
http://www.audiocircle.com/index.php?topic=454.0
MarkR7
Price reduced..... :thumb:
