Help
0 Members and 1 Guest are viewing this topic. Read 4878 times.
vinyl_guy
Re: Help
« Reply #20 on: 27 Feb 2014, 08:26 pm »
Air dried after the rinse, or back on the Loricraft to dry?
I dry on the Loricraft and then put the record in the Audio Desk which has an air dry cycle after the ultrasonic cleaning. The cycle takes about 6 minutes from start to finish.
Gzerro
Re: Help
« Reply #21 on: 27 Feb 2014, 09:50 pm »
Do you air dry after the rinse?
I dry on my record cleaning machine (KAB vacuum type machine).
I think air drying would be worse then not cleaning at all - any dirt or contamination left after cleaning would dry onto the record surface.
Quiet Earth
Re: Help
« Reply #22 on: 28 Feb 2014, 01:31 am »
That's sort of what I was thinking. But then I also thought that if I did an extra rinse with some kind of pure water I should also rinse the felt pads (or lips) on my machine too. But then that's getting a little too anal for me. I might try an extra rinse with distiller water and see if I notice a difference. Cheap enough experiment.
By the way, that "air dry" problem is exactly what Keith Monks said he did not like about the new ultrasonic record cleaning machines. He said that the ultrasonic machines do a very good job at cleaning the record, but not at removing the liquid from the record. He convinced me that there would still be stuff left on the record from the blow drying method. Of course, he sells a different kind of machine so obviously he will have a different opinion about what is best.
I personally believe that there is really only so much you can do to make a record quiet. I would like to be proven wrong about that. I mean I really do want to be wrong and discover the magic trick.
