Tube damper for the 6H30P-DR
jk@home
« on: 26 Feb 2014, 12:22 pm »
I have only one tube in my system, a 6H30P-DR in my Dodds buffer unit. What's the recommended damper for this tube? If it makes any difference, the tube is mounted horizontally.
kernelbob
Re: Tube damper for the 6H30P-DR
« Reply #1 on: 26 Feb 2014, 01:28 pm »
Go with the Herbies "Ultrasonic" damper.  I had your same tube in an ARC REF3.  The improvement with the Herbies damper over a damping ring was obvious.
Herbie
    • Herbie's Audio Lab
« Reply #2 on: 26 Feb 2014, 01:30 pm »
UltraSonic Rx-9.
http://herbiesaudiolab.net/rx.htm#9
Steve Herbelin
Herbie's Audio Lab
jk@home
« Reply #3 on: 26 Feb 2014, 02:46 pm »
Thank you!
jparkhur
« Reply #4 on: 26 Feb 2014, 02:51 pm »
Yes.. I will be ordering an rx9 also.   the silicon thing was terrible.... terrible I say..
JP
jk@home
« Reply #5 on: 26 Feb 2014, 04:30 pm »
UltraSonic Rx-9.
Steve Herbelin
Herbie's Audio Lab
Order form emailed. :thumb:
« Reply #6 on: 26 Feb 2014, 04:35 pm »
Seems to me the UltraSonic RX9 are the top of the line on Herbie site.
Do it is the best suited to 6N1P / 6N6P??
rollo
  • Rollo Audio Consulting -
« Reply #7 on: 26 Feb 2014, 05:08 pm »
  Just through those rings away. We strongly recco Herbies for Dodd 6H30 based preamp to our Dodd customers. Next up Tenderfeet as well. Herbie's products in our opinion are the real deal.
charles
