Music Direct Issue Advice
0 Members and 1 Guest are viewing this topic. Read 6158 times.
loving_it
Re: Music Direct Issue Advice
« Reply #20 on: 24 Feb 2014, 04:31 pm »
Long story short I was told this morning by Bes it looks like a want a picture perfect product and it would best at this time if I just sent the item back for a refund . This it what I will be doing this morning .
Gzerro
« Reply #21 on: 24 Feb 2014, 04:59 pm »
What a disappointing story.
When multiple errors/misunderstandings occur sometimes a refund is the best way to move forward. Occasionally things just don't work out despite good intentions on both sides. I think you are doing the right thing to making sure you get an item you are 100% satisfied with.
Good luck on getting a new table!
Wayner
« Reply #22 on: 24 Feb 2014, 07:41 pm »
Yes, that reply was a bad one. Every customer should get nothing more, nothing less then what is paid for. You did not pay for a "blemished" unit, so, yes, yours should be perfect. If I bought one, I'd expect nothing less from MD or VPI. They get good press, so they should live up to nothing less then "the best" in product or customer service.
Right now, I'd say shame on MD. Many ways to handle this one and they, in my opinion, dropped the ball. So I think you are certainly on the right track, getting VPI directly involved. Your problem will get fixed and eventually, you will be a happy camper. You got a great table, at a discount, with a few bugs to get worked out (that you should not have had to).
The winner in almost every case like this is the one that perseveres the goal. An easy fix for MD was to send your unit back (I'm sure at your expense) and wash their hands of it. WRONG!
I do lots of business with MD, but I certainly can't defend this. I couldn't defend any business in my small town to do what they did.
All I can say is move on and 'get r done!
Wayner
loving_it
« Reply #23 on: 25 Feb 2014, 04:02 pm »
The final outcome is that I excepted a 350.00 refund from Music Direct  and kept the table , I dropped the TT off yesterday to a private party to have it touched up .
I would like to make clear this was not an issue with the manufacturer- VPI went way out of there way for me and has excellent customer service . I would buy another VPI product in a heartbeat .
I apologize violating the dirty laundry policy
