0 Members and 1 Guest are viewing this topic. Read 10376 times.
Hi.Definitely different. Any specs?Guy 13
Sensitivity: 89dB (powered woofer in stand)Response: 20Hz -50KHz The monitor portion is within a 1.5dB window from 250Hz to beyond audible. The I-nuke amp allows tailoring of bass response to match room characteristics.Weight: Monitor portion - ~30 pounds. Bass bin stands - ~80lb
Looks neat. What veneer is that?
That's very nice looking Pete!Where is it going to fit into your lineup? How's the soundstage?Hey - are you planning on demoing at THE Newport Beach this year? Would be nice to listen to these if you take them.
Did you replace the fan in the iNuke or just disconnect it? Do you think the SQ of the Inuke is good enough for a mid woofer? The built-in DSP certainly is handy.
I'm Ryan ... the good looking one, not Pete
