0 Members and 1 Guest are viewing this topic. Read 7087 times.
The specs (0.47UF 600V) stay the same regardless of the manufacturer of the CD player? If not, what specs are recommended?
Does he mean connect caps across the AC wires (hot/neutral) that come in through the chassis prior to them connecting to anything on the circuit board? If not, please describe in more detail.
Cause for alarm?! What?! "Install BEHIND the fuse SO THEY DON'T FAIL AND CATCH FIRE, while the unit is un-attended." Why would they possibly catch fire? Is this a mod "for professionals only"? Or does he mean, insert them somewhere on the wires BETWEEN the fuse and the circuit board?
The Auricaps do have one lead colored red, and the other is black. They state the red is to be connected to the hot line, and the black to neutral. If your player has an IEC inlet, the easiest way to install them is to solder them on the inside of the chassis on the IEC hot and neutral pins.
MarkC"But this would put the caps ahead of the fuse rather than behind it. So if you had a short the protection you would rely on would be your 15 or 20 amp breaker rather than your 2 or 3 amp fuse in the cdp"Trust me the fuse will blow before the breaker goes.
