Carbon fiber outlet covers
0 Members and 1 Guest are viewing this topic. Read 7351 times.
Bob2
Re: Carbon fiber outlet covers
« Reply #20 on: 13 Feb 2014, 12:13 am »
I think the carbon fibre thing is just bs.....
I use only the finest 6061 billet aluminum in my listening room!
Medical grade outlets do a fine job.........................
lacro
« Reply #21 on: 13 Feb 2014, 01:27 am »
Which begs the question can CF be laminated?  I was under the impression that ALL laminated carbon fiber isn't really carbon fiber but is just carbon fiber look vinyl.
I did see a video (can't find it now) on how carbon fiber weave/cloth could be mached onto objects one layer at a time with resin but that's not laminating.
 I think the term laminating in regards to composites simply means "layering" one material to another. I laminate carbon fiber/fiberglass quite often with epoxy. It's not vinyl, but real carbon fiber twill weave cloth. The term used in this process IS laminating.
The carbon fiber outlet covers are probably laminated with fiberglass to build thickness/strength without using multiple layers of CF which is more expensive.
charmerci
« Reply #22 on: 13 Feb 2014, 04:00 am »
Art deco covers! Cool!  :thumb:
