0 Members and 1 Guest are viewing this topic. Read 186681 times.
bwillcox, return it!!! The issues you are having seem completely unliveable and there's gotta be an issue with your unit.
Yeah... I was looking at tablets and it looks like I can get a 7" Toshiba, a fairly basic unit, for $99 at Best Buy. I may pick it up and see if the HDD remote app works better with it that my phone. What are other people using for a remote device and how is it working? Anyone? Bueller?
I've been using a 7" Google Nexus that has been working pretty well for me...well till my current problem with the HAP-Z1ES itself.
Yeah, well I updated my HAP-Z1ES player and the transfer program and now I can't successfully transfer any tracks to the player. I even tried a factory reset and still no dice. The transfer program claims to be transferring 121 tracks (should be over 1700 now that I did the reset) and takes an appropriate amount of time (seems to be transferring the bits to the box), but nothing ever gets there. So, now I'm stuck with just the 15 tracks that Sony initially provided with the unit.
I re-started the process of transferring all my music again, yesterday, and it's just completely frozen yet again ! I've had to do another factory re-set....quickly falling out of love, with this player !
Not sure if this is the problem, but just check that your computer or hard drive is not going to "sleep" because of an energy saver mode being enabled. I had one occurrence of the transfer hanging and its because my computerh went dormant, not the HAP-Z1ES.
When the HAP-Z1ES freezes, you might want to try what works for me. Press and hold the power button (for at least 5 seconds, longer if need be). That should then cause it to shutdown w/o having to pull the plug.
