0 Members and 2 Guests are viewing this topic. Read 189041 times.
You AV receiver will be fine. The HAP-Z1ES does all the decoding and connects with analog outs.
Thank you, for your help / feedback. I just now have a decision to buy the HAP-Z1ES, or go with the HAP-S1 ( and speakers ) as a separate music system ?? Ideally, I'd like the flagship player, but so expensive !!Has anyone compared both players, and if so, does the HAP-Z1ES, justify the price difference, regards, purely based on sound ?
Put it in this way, after your purchase of Z1ES, the next upgrade will be top DCS, top Emm, etc. Those in between , don't bother, as you're not a reviewer.Moreover, the Z1ES comes with DSD re-engine, which is not available in S1. This feature will "re-make" all your music file to DSD quality, just like those re-mixed or re-mastered SACD from the shelf, without paying any cents. And you've an option to toggle between DSD-re-engine and non-DSD-re-engine, if you want to have some fun of it.And Z1-ES offer internet radio as well, it come free, and you're able to convert it to DSD quality as well, as long as the Z1ES is still functioning.
after 2.5 months of listening to this player - the 96khz and the 192khz recordings using the upsampler on the sony sound very special - more so than most of the dsd 2.8mhz upsampled to double dsd - go figurethe 96 and 192 to me in general sound much more real and open and spacious - although the "shelby lynne" sounds spectacular - the best dsd 2.8 i have heard - however this is mostly the exception
Can you transfer converted dsd ( 2.8mhz - double dsd ) files from jriver ?
By the way, I have not noticed any owners mention this...but the outputs of this Sony machine are inverted polarity, so the right thing to do is swap black/red at your amp or speakers (both channels). And often Dan's tubed mods (and tubed preamps) invert too...but in this case (his Sony HAP-Z1ES Truth Mod) it doesn't..so I needed to swap black/red leads. I realize many recordings are done inverted, so this is somewhat theoretical, but what the heck. I want to compare the same recordings I'm used to, so need to reduce variables as much as possible. I think Vinnie's mods swap them back...but will make sure once the unit arrives.Edit: Dan takes his signal right from the DAC, before Sony's own phase inverting circuitry....so nevermind...his unit does not require me to change anything. Stock owners should, though. I have an email into Vinnie to ask about his, but I think he works the same as Dan.
My main concern is, I don't have high end speakers or AV Receiver, to get the true sonic benefit of this player, and at a cost of £2000, I can't afford to upgrade my system. ( I still want one though ! )
Has anyone compared this to the Auralic?
The Vega? No comparison, the Vega is a dedicated DAC at almost 2x the price, and is quite a bit better on everything. The Auralic Aries is their streamer and not released yet. I will have the first (or one of the first) one for US review and will let you know how it does soon.
I was guessing, but you never know as the Sony is brand new... I bet an Aries/Vega combo will sound amazing.
The Sony is no slouch though. It is very musical and immersive, It does not have the best image focus, stage depth, nor the quietest background, but it does have an ability to engage you to with the music.
