How can I convert a DVD (w/ hi-rez audio files embedded) to audio format (AIFF)?
dburna
I have Eric Clapton's "Slowhand" (Deluxe Edition) and it contains a DVD that has hi-rez files (5.1 and 2.0 remasters) of the CD.  The files are in VOB format, and there is not a 1-to-1 relationship between VOB files to tracks.  Is there anything I can do to convert these files to a recognizable audio format so I can play them on my main stereo?  I don't want to play them on a DVD player on my A/V rig.
I have tried a few Mac-based format conversion programs to convert VOB -> AIFF, but they either don't work well (lots of drop-outs/distortion) or they choke on the VOB files.  I thought I might need something specialized to convert a video file -> audio while stripping out the (extraneous) video content.
Any suggestions?  Cheaper is always better.
Thanks,  -dB
rbbert
Run Windows?  There are quite a few options then
mhconley
I use DVD Audio Extractor: http://www.dvdae.com/dvdae
It's available for Windows, OSX and Linux.
Martin
Austin08
Martin
+1
rbbert
I use the Windows version of DVD Audio Extractor, didn't know it was also available for Mac
lamb1123
I think you can use a DVD converter to convert DVD to audio format. If you are a Windows user, you can use Freemake video converter which is a freeware. You just need to select an audio format as output format after importing the DVD to the software and then convert. However, I want to know where did you get the DVD, if you bought it abroad, I think you have to use other paid software like Leawo (used it, works pretty well) to disable region code on it.
« Last Edit: 26 Jan 2014, 02:01 am by lamb1123 »
