Suggestions needed
0 Members and 1 Guest are viewing this topic. Read 1307 times.
cliffy
Suggestions needed
« on: 21 Jan 2014, 03:00 pm »
I am leaning towards ditching my Bryston SP2 and Nuforce Ref9SEV3 monos in place of an Integrated for space constraints.
Any thoughts on what a suitable option might be?  I cant replace with a 7" tall behemoth.  Ideally the height would be less than 5" including feet.
Sources are:  Comcast cable box, SB Touch, Apple TV, Oppo DVD, Onkyo CD, Nintendo Wii.  I also use a DSpeaker Anti-Mode Dual Core.
Speakers are custom in-wall VMPS 626 and a REL sub.
Budget not a concern as long as it passes the WAF.
geowak
Re: Suggestions needed
« Reply #1 on: 21 Jan 2014, 03:24 pm »
If you like Bryston, why not go with Bryston integrated. I heard it's very good. The one that I did hear, that I can say is fine, is the Musical Fidelity M6500i. Truly an exceptional dual mono beast. http://www.musicalfidelity.com/products/m6series/m6500i/
avta
« Reply #2 on: 21 Jan 2014, 03:28 pm »
Just happened to hear that unit while auditioning some speakers. It was what the salesperson selected to demonstrate the speakers. He could have chosen other amps as I saw Parasound and Ayre. I thought the sound was excellent.
cliffy
« Reply #3 on: 21 Jan 2014, 03:37 pm »
The 6500i is too tall. The 60i has too few inputs.
Thanks for the suggestions. Keep them coming!
The Bryston B135 with DAC may work but I think I want to try a different asthetic.
avta
