Mcintosh MC275 amp
spotlightaudio
Mcintosh MC275 amp
« on: 20 Jan 2014, 05:28 pm »
Hi Herbie,
What would you recommend to replace the stock rubber feet on this tube amp? I think they use a 8/32 screw.
Thank You.
Herbie
    • Herbie's Audio Lab
Re: Mcintosh MC275 amp
« Reply #1 on: 20 Jan 2014, 05:46 pm »
Four Extra-Firm Tenderfoot isolation feet; no need for any screws.
http://herbiesaudiolab.net/compfeet.htm#tender
Steve Herbelin
Herbie's Audio Lab
spotlightaudio
« Reply #2 on: 20 Jan 2014, 10:25 pm »
Thanks for the reply Steve. Would I loose anything by using the threaded stud glider, as these would allow easier placement on the shelves do to the weight.
Herbie
« Reply #3 on: 20 Jan 2014, 10:47 pm »
Threaded Stud Gliders should do very well.
Herbie's Audio Lab
efhjr
  • Why, why, why, why are we sleeping?
« Reply #4 on: 10 Feb 2014, 08:49 pm »
I use three Iso-Cups with Supersonic Hardballs under each of my McIntosh MC30s.
Amazing improvement, even better than Tenderfeet.    :D
