settings on the mac mini ??
2bigears
« on: 18 Jan 2014, 11:37 pm »
 :D  hello mac mini pros .. I had to re=boot my iTunes and I was wondering on the settings to record into storage.
          would the setting default to standard ?? if you want to go lossless ,, where do you check these settings to be sure your down loading the best
              sound you can ..  any words , thank you very much.. I really want to start plugging the machine with cds again !!!!  :D
         soooo, if you go to storage with the cd. it is put in a format ,, then when you play it converts to play ?? if you have the original cd,, playing the cd is the best sound ??
            sorry,, me confused...
jtwrace
    • TIPP YouTube Channel
Re: settings on the mac mini ??
« Reply #1 on: 19 Jan 2014, 01:55 am »
It's a little old but should do the trick.  See here.
