Gasket tape for speaker back?
0 Members and 1 Guest are viewing this topic. Read 8236 times.
brj
« on: 16 Jan 2014, 07:54 pm »
Hi all.
My newly finished speakers use a compressible foam gasket tape around the edges of the rectangular, removable backs of the speakers.
The tape may have been overly compressed and the inside of the cabinet backs still a bit tacky from insufficient curing of the finish gloss, but regardless of the exact reason, the tape stuck to the inside of the removable speaker back every bit as strongly as it did to the cabinet itself.  If it wasn't for the grip and leverage afforded me by the pass-throughs used to connect my speaker wires directly to the drivers, I never would have been able to remove the backs without damaging the cabinets.  The non-adhesive side actually bonded tightly enough to the cabinet back in a few spots that it actually tore off the surface when removing the back.
The existing foam tape is roughly 3/8" wide and 1/8" thick with a (weak) self adhesive on one side.  When compressed, it is rather slow to return to its original uncompressed state.  It looks like it might be the gasket tape from Parts Express.
Does anyone have a recommendation for a gasket solution with a strong adhesive on one side that is perhaps less "grippy" on the other?  Perhaps one a bit thinner so that it doesn't have to compress quite as much?
Mark Korda
    • Dawkus
Re: Gasket tape for speaker back?
« Reply #1 on: 16 Jan 2014, 10:42 pm »
Hi Brj, I have a roll of that Parts Express gasket tape and it sucks! I love Parts Express but that tape just makes a mess. Years ago Frank Van Alstine wrote in his free Audio Basics news letter about using modeling clay.It never dries out and is always pliable. I started using it for woofer and tweeter gaskets. Just shape it with your fingers and a wall paper seam roller helps to even it out. It makes the best seal without the mess. If it sticks to your woofer basket just scrape it off with a credit card or cheap plastic putty knife. Then Windex or alchohol or try whatever for any residue with a clean rag.
This is a 1/2 inch gasket I made for a 8 inch co-ax. It's brown clay.I trimmed it clean using the side of a credit card after screwing the woofer in. The clay almost holds the woofer in all by itself so no need for tightening the screws too hard,you don't want to squish it out. Take care...Mark Korda
brj
« Reply #2 on: 16 Jan 2014, 11:05 pm »
Thanks, Mark!
Unfortunately, clay won't work as I need an easily separated seal.  I'm not sealing drivers, but looking for a gasket to air seal the removable rear panels of my speaker cabinets through which all access occurs.  (The drivers are flush mounted from inside the cabinet - no external screws.)  I need to be able to unscrew the (14!) screws that hold the rear panel in place and remove it at will.
Thanks again!
Mark Korda
    • Dawkus
« Reply #3 on: 16 Jan 2014, 11:45 pm »
Hi Brj, This is something you could try. Get an old car or truck inner tube,the kind you go tubeing down the river with. Cut in half all around the center the entire outer circular tread area,where the outer tread would be. Get a metal strait edge(metal or wood yard stick) and with a razor knife trim rubber strips to the width you stated.You might have to cut the strip in different places but abut the edges, edge to edge, don't over lap,like wallpapering.To keep it in place before you attach the back panel use little dabs of painters caulk to act like a little adhesive.The caulk should come right off if its just a little dab every four inches or so with a putty knife when you need to take off the panel in the future. When you come to a screw hole,use a paper punch to make a clean hole in the rubber gasket that won't disrupt it when you re screw the panel on.That would make a removable air tight seal that even Lloyd Bridges of Sea Hunt would be proud of....Mark Korda.
Mark Korda
    • Dawkus
« Reply #4 on: 16 Jan 2014, 11:58 pm »
Brj, I got an easier one. It's  right in my hands.The hardware store has a roll of tape in the plumbing section.I bought a roll to wrap around my bathroom sink drain for a temporary fix.It would work perfectly. It's rugged with a tiny tack,not much,and it's about an inch wide,comes in a roll,flexible,and about 1/32 or 1/16 inch thick. It cost me about 8 bucks and is in the plumbing section made to wrap pipes.Use the paper punch idea too(the inner roll says UL insulating tape 2CF8)...it's really rugged....Mark K.
Mark Korda
    • Dawkus
« Reply #5 on: 17 Jan 2014, 12:07 am »
http://www.lowes.com/pd_26668-66601-86001_4294715748__?productId=1076397&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=...........Mark Korda
GT Audio Works
« Reply #6 on: 17 Jan 2014, 01:10 am »
I have used this stuff for a similar purpose and has worked well...only one side has adhesive  http://www.homedepot.com/p/Frost-King-E-O-3-8-in-x-17-ft-Closed-Cell-Weather-Seal-Tape-V443H/100205904#
Also you may want to try Gorilla tape  http://www.homedepot.com/p/Gorilla-Glue-1-7-8-in-x-12-yds-Heavy-Duty-Duct-Tape-60012/100557598# this stuff sticks like crazy..I find it a necessity around my house.
You could tear multiple strips and build up a few layers to create a gasket surface..again only one side would have adhesive for easy removal later.   Greg
mgalusha
« Reply #7 on: 17 Jan 2014, 03:19 pm »
Rope caulk works pretty well for this. It's about 3/16" in diameter and can easily be rolled smaller. $5 at home depot. I have some, happy to give you enough but the gas would likely cost more than just getting it from agent orange. ;-)
http://www.homedepot.com/p/MD-Building-Products-1-8-in-x-90-ft-Flexible-Caulking-Cord-Weatherstrip-71548/100353483#.UtlI0tBlC5M
