Modify a SR3-15 for 12V
simonhiggs
« on: 12 Jan 2014, 03:12 pm »
Is it possible to modify a SR3-15 to provide 12V output?
Just trying to work out whether to sell the PSU with my DAC or hang onto it for possible future use.
Thanks, Simon.
Paul Hynes
    • http://www.paulhynesdesign.com
Re: Modify a SR3-15 for 12V
« Reply #1 on: 13 Jan 2014, 02:44 pm »
Hello Simon,
There is an adjustment potentiometer internally that you can adjust the output range with. It may reach 12v from 15v. If not I can tell you how to modify the range. You will have to de-rate the power supply output current by 20% to avoid overheating due to the larger voltage drop across the voltage regulator.
Regards
Paul
wisnon
« Reply #2 on: 13 Jan 2014, 06:38 pm »
How do you de-rate the current output?
paul79
« Reply #3 on: 13 Jan 2014, 07:41 pm »
I believe it means that your supply at 12v will be a 2.4 amp supply, instead of 3 amp.
wisnon
« Reply #4 on: 13 Jan 2014, 10:39 pm »
Great, thanks.
