critique my parts choices-server
0 Members and 1 Guest are viewing this topic. Read 1266 times.
raysracing
« on: 3 Jan 2014, 08:30 pm »
Micro Center Micro ATX case http://www.microcenter.com/product/406577/PS_23B0_mATX_Computer_Case
Core i3-3245
as rock motherboard H61M-DGS 1155 http://www.microcenter.com/product/410192/H61M-DGS_1155_mATX_Intel_Motherboard
Windows home server 2012
2x2gb DDR3 1600 ram
Now to source a quiet power supply and SSD. I plan on the PPang USB card.
I'll try and use pullout parts (optical drive) for other things from the PC that just died which was my server and parts from my old machine that got modded for a gaming PC.
Sorry for all of the edits.
« Last Edit: 3 Jan 2014, 09:37 pm by raysracing »
raysracing
Re: critique my parts choices-server
« Reply #1 on: 3 Jan 2014, 10:08 pm »
My big question is if the motherboard and processor are ok?  Ive read some other posts and I know Xeon's are better, but they cost more too.  I also know I will replace the power supply on the SSD with a battery PS.
This maybe goes without saying this is a budget build. I won't even have the pang USB card for awhile.
Ray
raysracing
« Reply #2 on: 4 Jan 2014, 10:17 pm »
  Two more questions.
Is there any difference between the Toshiba Q Series Pro or Samsung 840 eve SSD's for this server? The 128GB are on sale.
I believe I should need minimal power as I won't have much in this baby and plan on shutting down all unnecessary programs and services.  Are there any super quiet power supplies to look at?
TIA,
Ray
dB Cooper
« Reply #3 on: 5 Jan 2014, 01:55 am »
Looks like Computer Audiophile might yield more feedback re your question. For whatever reason, seems to be "crickets" here.
raysracing
« Reply #4 on: 6 Jan 2014, 07:54 pm »
Thanks. There is so much info on CA I may not need to ask too many questions now. My barebones untweaked PC is running. My first PC build and damn that was so easy it was silly. Needs help for sure, but it plays music through my DAC so it is a great start. Shrill and sometimes I must be hearing the jitter (Affects of jitter) and maybe those power supply issues, but that is what is going to be so fun about this. Tweaking it on a budget.
