0 Members and 1 Guest are viewing this topic. Read 7317 times.
This test might be useless to some, but for me it’s useful, as it give me an idea of where the offender frequencies are.
Hi Guy,I did a similar test when I had to prove to a vendor that the tweeters in my speakers weren't working properly. I used the SPL meter like you but I used the Stereophile test CD that contains frequency tracks from 10 to 20K Hz. I'm not sure how your results will tell you what exactly to do with your room treatments to tame those hot spots of yours. What are you thinking?
Ethan is of course absolutely correct about the measurements. However how they're going to be implemented is just as important. When the usual answer is use some bass traps, and that's the limit of what is going to be done, it's only academic to go more refined than 1/3 octave. If you're building a dedicated listening room then you need more precision. So, what are your ultimate goals guy13?
Hi Letitroll98 and all Audio Circle members.My ultimate goal ? ? ?To tell you about my ultimate goal, I have to see in the future, which I cannot , at least right now.So that you understand better my position, I have to share with you my (life) BIG problem.I am not and I will never be shy of sharing some things about my life with other people, so they understand more clearly the (My) situation.First my revenues from my Canadian government pension (Retirement fund) as been cut by 75% due to unpaid due to my ex-wife in Canada. (Total amount to be paid is 350,000 Cnd $Second, I am not sure when I will be going back to Canada due to my (Now) extremely small revenu, income.Therefore, if I invest money on acoustic treatment on my listening room and I go back to Canada, that investment will be lost.Sorry to annoy you with all that, but now you have a better picture of my (Financial) situation.Therefore, for now, I will not do much, unless I win the Vietnamese jack pot which is only about maximum 100,000 USD.And, If I do win at the lottery, I will invest that money on my return to my home country Canada.That's it for now.Any comments, suggestions are all welcomeor if you want to share your win at the lottery, that's O.K. with me. Guy 13
If insulation and wood are available there you can make your own bass traps. 12" of rockwool or fiberglass or cotton insulation in a 48"x24"x12" frame covered in burlap will work fine as a bass trap.
OK, first please clarify. You state that background noise is 40 dB, so should your chart be read as 40 dB higher than the stated readings? (That would place them up to 130 dB, which should be painfully loud.) If not, how do you have readings below 40 dB? And how is it that those 4 good sized woofers (not familiar with your speakers) are 30 dB down at 50 Hz? Do you listen near field (where the mike is shown)? Why not measure from where you listen? Not sure if your speakers are dipole or bipole, or if near field testing makes sense/works with either design.My first attempt used a Radio Shack analog meter with Stereophile CD test tones, but got better results using a Behringer DEQ 2496 with ECM microphone (both from my near field listening position). Do you know how accurate your signal generator and/or meter are? (Radio Shack meters have well documented inaccuracies, especially at lower frequencies.) I also recommend doing each channel separately (my matched drivers varied in my nearly symmetrical room by up to 6.5 dB).As I've stated before, the room acoustics priorities should be: speakers (duh); proper room (bigger is better with good length/width/height ratios to avoid reinforcing echo); treatments (but don't over do as we're conditioned to listen to 'typically furnished' rooms); EQ (only as a finishing touch). Read Floyd E. Toole's 'Sound Reproduction'. It recommends a variety of good room ratios, touches on treatments, and pushes the need for having multiple subs. Without multiple subs no room will produce flat bass response, except in particular locations at particular frequencies.
Thanks, but still confused. Do the readings on your graph include the 40 dB background? (If so, how do you get readings under 40 dB?)If the readings on your graph have the 40 dB background subtracted, you seemingly would have been listening to peaks of 130 dB (painfully loud). Which is it?Next question: are your speakers dipole (both woofers fire in the same direction at the same time), or bipole (one woofer fires forward as the other fires backwards on each speaker)?If dipole, it seems to me that near field measurements (or listening) aren't going to be realistic/recommended as the in/near the plane of the speakers the front and back out of phase waves cancel each other out.
Thanks Guy, just had a hard time reading the left edge of your graph (it's partially cut off on my screen).Glad to find out they're bipoles (acting like a 360 degree source) as that makes more sense to me, especially for near field listening. Surprised that those drivers don't go lower, OTOH there's no cabinet to help either.BTW it's still 2013 here but 2014 there, so Happy (non-chinese) New Year.
Hi Guy,Since you can't get room treatments in Vietnam maybe you could do some improvising with the materials you do have. Like covering the walls with thick tapestries. This might not work as well as GIK treatments but it should offer some improvement. Corner traps will require a bit more creativity. Maybe large sculptures in the corners? Preferably geometric ones that would diffuse the bass a bit?
Guy's speakers are OB dipole, woofers are wired out of phase.Lin
