0 Members and 9 Guests are viewing this topic. Read 593274 times.
VMPS Original Subwoofer Audiophile Grade - (Boston, MA) $100http://boston.craigslist.org/bmw/ele/4944208101.html"VMPS Subwoofer in excellent physical and functional working condition but in need of some TLC.The subwoofer works but one of the voice coils in the dual voice coil driver isn't working. Running it from the sub out on the receiver to a dedicated sub woofer amp effectively negates this issue as only one voice coil is needed. The other issue is that the foam surround on the down firing passive radiator has begun to dry rot and will need to be replaced. For these reasons it's offered as a project for the bargain price of $100. I have to think the furniture quality cabinet alone is worth more than that that to a hobbyist. It includes the original owner's manual as well as the tinted glass that sits on top of the cabinet making it into a nice end table.http://www.audiocircle.com/index.php?topic=26563.0I will also offer my dedicated TBI 200su subwoofer amplifier to the buyer for an additional $150 to interested buyers (this is a $450 amp). You can run two separate passive subs with this BASH amp. Both items can be auditioned.http://www.stereotimes.com/speak112204.shtmlhttp://tbisound.com/dsp_products_subwtbi200.aspVMPS SUB $100 (Optional TBI SUBWOOFER AMP) $150 - $250 for the package.Local cash or trade offers only. No scams."
VMPS Tower 2 Special Edition - Local Pickup Only - (Chicago, IL) $1200http://app.audiogon.com/listings/full-range-vmps-tower-2-special-edition-local-pick-2015-03-04-speakers-60601-chicago-il"A nice pair traded in all original. The foam may need to be replaced but wanted to show an example of a really nice unit of this age. Very nice sound for low price."
REPOSThttp://www.audiocircle.com/index.php?topic=132519.0
REPOSTVMPS Center speaker - (Kenosha, Wisconsin) $450 http://racine.craigslist.org/ele/4955232450.html"I have a VMPS LRC for sale. It is Cherry in color with a black cloth grill. It is in fair condition. This speaker originally came with a spiral ribbon tweeter which I replaced with a FST ribbon tweeters (Aurum Cantus G2 Ribbon Tweeter, $192 at Parts Express) It has a single Neo Panel midrange and (2) 6" Carbon Fiber cone woofers. These are the upgraded 40oz Mega woofers VMPS offered as an upgrade. The speaker includes two L pads to adjust treble and midrange output. Since the passing of Brian Cheney, VMPS has gone out of business and these speakers are no longer available but the last list price for a set like this was over $1,100.SpecificationsBass: - 2x 16 cm (6") WCF megawoofer, front reflex loadedMid: - rectangular 10 x 20 cm (4 x 8") Neo ribbon, 280 Hz - 6.9 kHzTreble: - FST, 6.9kHz - 30kHzImpedance & Sensitivity: - 4 Ohm (3.6 min.) 90 dB/1W/1mPower handling: - 250 W rms / 4 Ohms, 20 W min.Frequency response: - 35 Hz - 25 kHz +0/-3 dBDimensions & Weight: - 27H x 82W x 33Dcm, 23 kg (10,5"H x 32"W x 13"D, 50 lbs)Output levels and distortion: - max. 1%THD fullrange/1W, max. 110+ dB SPL / 1 mThe reason I rate this speakers as fair is the cabinet has one scratch on the end. I also replaced the plastic grill guides that broke when it was shipped to me with magnetic grill fasteners. When I mounted the FST, I did not mount it flush. All drivers work perfectly and none of the above effect the way the speaker sounds. You will be hard pressed to find a better sounding center channel at any price, note the how low these will go compared to there center channel speakers.I have 5 sets of VMPS speakers plus a LRC and a Larger Sub. The only reason for this sale is to downsize my living room system from a 5.1 to a 2.1 system.The speaker is too big and too heavy to ship so local pickup only. I can deliver these speakers in the Milwaukee/Chicago area with upfront payment and if you cover the gas costs."
What's the dark circle seen inside the slot?
