How much better is the HAP-100 than the HA-200?
kazsud
« on: 18 Dec 2013, 10:01 pm »
I had the HAP-100 for a hot minute and was wondering how it compared to the HA-200?
John Casler
Re: How much better is the HAP-100 than the HA-200?
« Reply #1 on: 18 Dec 2013, 10:23 pm »
It may not be that one is better than the other except if you are looking at the application(s).
The HAP-100 is a High Quality Stereo 2 Channel Preamp "and" Class A Headphone amp, so if you want the best of both worlds you employ it.
The HA-200 is a Headphone Amp "only", is also Class A, but can be bridged with a 2nd HA-200 for 2 times the power for one of the best Headphone amps available.
Unique to HA-200 is the ability to quadruple the output power by running 'Balanced Headphone Mode', with using 2 HA-200.  In the 'Balanced Headphone Mode', simply use the XLR input (one on each HA-200) and output.
nuforce-casey
« Reply #2 on: 19 Dec 2013, 12:29 am »
HA-200 when bridged, one gets 4 times the power.
viggen
« Reply #3 on: 31 Dec 2013, 05:00 am »
What headphones are you using?
From the literature, it seems the HA-200 is better with harder to drive phones because of it's current drive technology.  And, bridging it not only increases power but also channel separation.
kazsud
« Reply #4 on: 31 Dec 2013, 07:36 pm »
I guess what I am getting at is two of ha-200 in bridged mode better for the hd800s than the hap-100?
