Anyone still using a Squeezebox classic?
0 Members and 1 Guest are viewing this topic. Read 1155 times.
geowak
« on: 12 Dec 2013, 05:55 pm »
Is the SB Classic still usable? Had mine disconnected for two years when Logitech said they would discontinue. Can I still use it?
mcgsxr
Re: Anyone still using a Squeezbox classic?
« Reply #1 on: 12 Dec 2013, 05:58 pm »
I am using one with no problems.  It connects to my LMS running on a netbook locally.
I take it that it was Squeezebox.com that was being pulled down.
rajacat
  • Washington State
« Reply #2 on: 12 Dec 2013, 06:20 pm »
I'm still using a Bolder modded SB3. Squeezebox.com works well.
geowak
Re: Anyone still using a Squeezebox classic?
« Reply #3 on: 12 Dec 2013, 06:51 pm »
Good to know that I can still use it. Gonna add another system in a vacant room and need a source. Thanks for the info.
coke
« Reply #4 on: 12 Dec 2013, 08:04 pm »
I use a squeezebox duet and control it with my android phone.  Works very well
mcgsxr
« Reply #5 on: 12 Dec 2013, 08:05 pm »
I would really be in trouble if LMS stopped working.  I have 3 systems running off my install.
1 SB3 classic
1 VAMP (hacked Pogoplug)
1 USB-spdif converter right out of the netbook running LMS
I control them all with iPeng on either an iTouch or one of our iPads.
A great way (for almost free) to network my 2TB of FLAC through a couple of systems in my house.
My brother left the LMS family (mostly) and recently went with setting up Sonos (for a lot more $) in order to get Spotify up and running.
