And if it was me, I would at least stick the surface mount caps by the 3116 back in. I would guess the MR doesn't like a lot of capacitance close by, but a little sm cap with some trace in between should be OK.
Thanks Randy. The app notes for MR state the following, so if the SMD caps are as the TPA3116 datasheet circuit then I guess I could have left them in:"Ensure that no output cap is present. If this is unavoidable, try to make the cap value less than 0.1uF or greater than 20uF. It is possible to go much higher than this, into the thousands of microfarads, if certain precautions are taken..."With my Charlize I was not sure what the effect of the MR would be so I just soldered it in with all the caps still present to see what happened. The result was such a knockout that I never got around to trying without them - I just didn't want to mess with that sound at all. This time around I wish I had tried that first for comparison. I am too clumsy at soldering to reinstall them. I do have another Audiobah board to play with so may have to try that - it just means removing the input caps to get a like for like comparison as the dedicated amp for the Buffalo.
What makes you think any of the capacitors you removed are output capacitors? If you want to see output capacitors I can advise you to look at tpa3123 datasheet, page 1 simple schematic show 470uF output capacitors.http://www.ti.com/lit/ds/symlink/tpa3123d2.pdf
Hint: The Music Rail, like the TPA3116, needs decoupling capacitor soldered directly to pins to function properly.
Coilcraft SER2915L 10uh inductorsTDK .22uf 250v X7R caps (bootstraps)330uf 25v Panasonic hybrid electrolytics (PS caps)Wima FKP, MKP, and MKS for .68uf,10nf, and 1nf output filter caps36db gain resistor settingDayton MKP 2.2uf input capsJantzen Superior 2.2uf input capsAmp sounds *excellent*. Clean and clear, no grain or edge. *Pure*.Best build yet. All done now w/ the TPA. Ready to move on. I do want to get one of those power supplies that I think someone keeps mentioning. What are they again?
...My 2 cents...
