0 Members and 2 Guests are viewing this topic. Read 621118 times.
Thanks wushuliu for your reply.I need 25w+ to drive my monitors and I did read that the YJ 2.0 is the way to go.I have very limited soldering skills and was looking at the $88 finished version.I will be using an iFi iTube along with the amp(s) for a buffer stage.Can two of the YJ 2.0 units be used as mono blocks with the shorting of one input?(This can be done with the TBI with a 20%gain in output) Chris
Hi Chris, no the YJ units can not be made into mono blocks by just shorting inputs. The changes required are a little more involved.
Here's my TPA3116 build, just finished today. Listening to it now as I post this. So far, sounds at least as good as my TPA3110.The finished product is completely boxed up, but I thought that'd be a boring picture (using a Context Engineering chassis). Not as nice of work as Rhing's, but halfway decent I think. If you look closely, you'll notice there are three wires coming from the DC jack. The black one is taped off on the end. Must have been a cold solder joint, because on the first attempt at using it, no sound. DMM showed no voltage across the DC input. So I soldered on another wire, and accidentally used another yellow. So I put heat shrink tube on the end of the yellow so I can tell them apart. All my stuff always seems to have a little touch of ghetto.Right now it's on my desktop rig: FLAC rips to Cambridge Audio DACMagic (the original) to TPA3116 to Overnight Sensations speakers (DIY flatpack kit from Parts Express)...
Is this http://www.yuan-jing.com/tpa3116-class-d-2-0-stereo-power-amplifier-50w-50w an integrated amp? I'm toying with the idea of getting it and selling if it does not have enough power for my ONIX mini strata speakers. Also would consider buying a 3116 DIY made by a forum member. If anyone near Philly would be interested in buying the amp in the link if it does not work out for me of if anyone wants to get rid of a 3116 DIY for a decent price please PM me.I don't listen very loud and I've asked if other low power amps would work, but this 50W seems like it might work because I'm using an ONIX a6o amp and feel like it has plenty of power for the minis. Feedback is welcomed.
In the meantime, I installed a Panasonic EVJ 50kohm volume pot into my TPA3110D2 amp. As I mentioned before, I carefully soldered the wires using a third hand tool. in the photo, you can see that I wrapped the jaws of one of the alligator clips to keep the alligator teeth from biting into the wire insulation. After soldering each wire in place, I slid a short segment of 14AWG Teflon tubing over each soldered joint to avoid possible shorts. It also serves as a strain relief.Here is the volume pot installed next to the RCA inputs to keep the signal path as short as possible to minimize any RFI effects. Using my DMM and my ears, this volume pot is very well balanced, even at very low volumes. Interestingly, I have absolutely no noise coming through my speakers with my Sony ES SACD/DVD/CD player connected directly to the inputs of the amp integrated amp mode. The starting volume position is about 7 o'clock, and pushing it to 10 o'clock is plenty loud for my man cave. This little amp never ceases to amaze me.
Hey Rich...Would the Panasonic EVJ 50kohm volume pot also work on the 3116 blue board? I want to have an outboard pot in a small box to try with different boards.
@Rich I sent you an email via the forum (thinking it was PM) but I guess it did not go through. Anyway, maybe it is better to ask here so, people like me may get their answers.
Rhing, thanks for the clear description and pictures of how you upgraded your Sure TPA3110D2 board. Especially helpful was your recommendation of the Panasonic volume pot. For such a tiny little guy, it's surprisingly smooth, both physically and audio-wise. Note, though, that the specific product (EVJ-Y10F03A54) is now listed as obsolete on both Mouser and Digi-key sites so now would be a good time to get 'em if you want 'em. (There appear to be similar 50k ohm Panasonic potentiometers available.)
Connected a Panasonic EVJ-Y10F03A54 pot to my 3116 board tonight. It sounds good so far. I can unplug it from the board and connect direct to RCA outs for comparison or if I want to try a preamp. This is the pot Rhing suggested that worked great on the 3110 board.
Nice build! It really does pay off to mount these amps on some kind of board with angles drilled out to manage connections and wires. I've shorted too many connections and fried a few amps trying to rush things myself.I'm curious whether you can hear a difference between the YJ blue amp and the Sure TPA3110D2 amp. To my ears, the YJ blue amp sounds smoother, more tonally balanced from bass to treble, and it creates a larger and deeper soundstage when using the same power supply. I believe this has more to do with the Sure board's use of those tiny ceramic SMD caps than differences in the chips and their respective power specs. I'm saving up for a pair of Jensen JT-11P-1 transformers to convert the single-ended inputs (RCA jacks) to differential inputs (balanced inputs) on the amp board. I'll try this out on my Sure TPA3110D2 amp first, and also experiment with different film capacitors in place of the ceramic SMD input coupling caps on the board. I believe the TBI Millenia uses op amps to achieve the same conversion from single-ended inputs to the Texas Instruments TPA3100D2 amp's differential inputs. Even though they cost more, the transformers should do a better job for this. It sounds a bit over the top, but I think that this would take the amp to another level of performance.
Lacro,Where did you get those angled brackets from? I looked for them in Home Depot but did not have any luck.
lacro I see you use ferite beads with 3116 after LC outputfilter? did you have noise/hiss without them?
