TPA3110 and TPS3116 amps
0 Members and 1 Guest are viewing this topic. Read 620821 times.
Taterworks
Re: TPA3110 and TPS3116 amps
« Reply #180 on: 28 Jan 2014, 04:17 am »
Hello lacro,
What is the value of your two Silmic II caps?
Letitroll98
  • Too loud is just right
« Reply #181 on: 28 Jan 2014, 12:54 pm »
I think they're about $6.99 each.
Sorry, couldn't resist, maybe because they're capacitors and have very little resistance.
Please, stop me.
mboxler
« Reply #182 on: 28 Jan 2014, 03:07 pm »
I finished my Sure TPA3110 amp last week, and was using a 12V SLA battery for the PS.  I found and ordered this 12V laptop PS from Ebay...
http://www.ebay.com/itm/290727815800?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Measured 12.5 volts, so I plugged it in.  A big improvement driving my little Pioneers, and my wife's request to "get that big-ass battery out of the living room" has been fullfilled.
Mike
lacro
« Reply #183 on: 28 Jan 2014, 10:39 pm »
Hello lacro,
Taterworks:
1,000uF / 25V.
Letitroll98
« Reply #185 on: 28 Jan 2014, 11:19 pm »
Well if they are not going to provide good parts on-board, at least now there's a board so you can swap stuff easily.
FYI: Due to the Chinese New Year Holiday, our factory will be closed from 25 JAN - 8 FEB 2014.
You can place the order during this period. However, all our orders will be started to ship out form 12 FEB.
Folsom
« Reply #186 on: 28 Jan 2014, 11:28 pm »
Ya but it takes 2-3 weeks anyway.
Letitroll98
« Reply #187 on: 29 Jan 2014, 12:49 am »
Pretty kewl site regardless.
raysracing
« Reply #188 on: 29 Jan 2014, 12:46 pm »
I love my  (red board) TPA3116 board, but want to eliminate the volume control. Should I just buy another one (I believe the one with the green board has no volume pot).  Is there a way to remove it? if I remove it then what mods do I then need to do to hook it to a pre-amp?  Sorry, very low knowledge on power amp design.
Ray
mboxler
« Reply #189 on: 30 Jan 2014, 02:10 am »
Ray
Hi Ray
Removing the pot is fairly easy, if you have either a solder vacuum or solder wick.  I use the vacuum (radioshack), heat each for the six joints 'til the solder melts, and suck it off the board.  After a few passes, the pot will get loose and pull out.
You can then wire your RCA's to the vacant pot holes.  Salis Audio posted a picture showing a similar board
http://www.audiocircle.com/index.php?topic=122152.0
The middle holes are from the + pin of the RCA, the left holes from the - pin.
Solder wires from the two RCA jacks to the four holes marked in the picture.  Make sure to twist the + and - wires from each RCA to the board.  Connect your preamp to the RCA's, and you are ready for tunes  :D.
Hope that helps.
Mike
Folsom
« Reply #190 on: 30 Jan 2014, 02:29 am »
If you like the current input location, but have removed the pot, yoou can also jumper with wire the far right front with middle front, and far right back with middle back. That would leave ground disconnected at the old pots location but doesn't matter as ground is connected where you have inputs now.
Mr. Oczka
  • Audiophile in training
« Reply #191 on: 30 Jan 2014, 11:37 am »
Question about the tpa3116.  Received mine in the mail and was going to put in a box.  I want to connect it to some RCA jacks, so I removed the plastic connector exposing three prongs on the front of the board.  Right input, Ground and Left input.   When hooking them up, do I use the same ground for both the right and left inputs?  I would have thought there would be 2 separate grounds, one for the right input and one for the left input.  I prefer not to cook the board before I get to listen to it.  Thank you for any advise.
Tom
raysracing
« Reply #192 on: 30 Jan 2014, 01:19 pm »
Hi Ray
Hope that helps.
Mike
  Very helpful-thanks.  I hope it improves the sound even if a little bit.
raysracing
« Reply #193 on: 30 Jan 2014, 01:25 pm »
  I am using the crappy RCA dongle that you buy separately and it is already broken.  The RCA plugs I use are so tight that I removed them once and the plugs separated so I will likely replace them with something sturdier.
mboxler
« Reply #194 on: 31 Jan 2014, 07:24 pm »
Tom
Hey Tom
Yes, you can use the same ground for both.  If the board had two grounds, they would be connected anyway.
Mike
Mr. Oczka
« Reply #195 on: 31 Jan 2014, 07:58 pm »
Mike,
Thank you!  I'll wire it up tonite and give the amp a try.
Tom
murphy11
« Reply #196 on: 2 Feb 2014, 10:40 pm »
Would one of these amps work with a strata mini speaker at lower volumes?  http://www.hometheaterhifi.com/volume_13_4/onix-strata-mini-speakers-12-2006-part-1.html   I'm using a ONIX A60 amp and never push the volume past 9AM.  http://www.audiocircle.com/index.php?topic=81177.0
rhing
« Reply #197 on: 4 Feb 2014, 01:08 am »
I would be surprised if any if these amps could drive the Mini Stratas with any reasonable headroom. Those crossovers are current-eaters.
Folsom
« Reply #198 on: 4 Feb 2014, 01:23 am »
Some multiway speakers also have load impedences that class D will often puke out as some kinda joke. The AB amps will do better.
rhing
« Reply #199 on: 4 Feb 2014, 01:29 am »
Good point. The Mini Stratas have a crazy impedance curve, and probably would sound shrill with a TPA3110/TPA3116 Class D amp.
