It is a Panasonic FC 1800uF / 25V electrolytic cap soldered into the J8 thru-holes where the power supply is connected to Vcc. The twisted wires from the power connector are routed beneath the board and soldered to the cap and thru-holes for Vcc (+) and Ground (0V). Taterworks had tried this and so I gave it a try too and obtained the same improvements in bass response, a larger soundstage and improved tonality. This was really apparent when using this amp as a standalone integrated amp in my system. I would have preferred a 2200uF / 25V Panasonic FC/FM cap, but the height would not fit in the compact chassis. This is a fun amp to play around with if you have the right speakers to drive. I'm ready to try a TPA3116D2 amp now. I hope some good boards become available. The Yuan Jing boards don't look like they're as well constructed as the Sure TPA3110 board. I also need to explore power supplies that work well with these amps.
I'm curious about driving a set of low-efficiency, low-sensitivity headphones (Hifiman HE-6) with a Sure TPA3110 amp. These are orthodynamic (not conventional dynamic) headphones. I'd be driving them directly off the speaker taps. Any reason that I shouldn't try this pairing? (About the HE-6: Nominal impedance=43 ohms. Power rating=6 W. Efficiency=77 dB1mW, 91 dB1V.)
Just an FYI, the 3116 amps do not draw 5 amps - they use far, far less unless you are cranking high spl's/dynamic range or really want to have reserve for peak current. One owner measured only 40mA with their speakers (though full range). Also the 3116 is usable down to 6v. Consensus elsewhere is that 12-20v is the sweet spot. I use 12v SLA batteries.
24V SLA set-up for me and I love it. Nothing special in the wire, but was thinking is there a C&C wiring for the SLA set-up that would make a difference? I am using old thin wires cut from SMPS's. Maybe build a board of capacitors to add to the amp box for the incoming DC power?A friend stopped the other day and recommended I try one then two Optima batteries. A bit of an expensive experiment, but could be cool if it works (massive reserves for dynamics).
I haven't tried the Ferrite beads yet since I don't have any RFI problems, but I guess it wouldn't hurt to try them. As for trying different brands of power supply caps, I usually use Panasonic Aluminum electrolytic caps: FM, FC, ED, TS-ED, EE, TS-EE and TS-HA. I've used them in solid state and tube amp projects and they do not impart any sonic signature. On top of that, they are very dependable like a good Honda or Toyota car. And of course, they're cheap and cheerful. I have used Nichicon caps as well, and I like them, but I usually will lean to Panasonics. I have used Elna Silmic II caps for signal coupling and for cathode bypass caps with excellent results. I generally don't consider them for power supplies, although they might work well in the TPA31xx amps, because they do impart a certain amount of warmth if that's your preference. I have tried Rubycon ZA/ZL in power supplies that many have raved about. To me, they are overrated. They do their job, but they impart an electronic haze to the sound.If you study what some of the best American amp designers like Nelson Pass or John Curl use, they typically specify Panasonic and Nichicon caps.
I replaced the power supply caps on a new TPA3110D2 amp board with Elna Silmic II caps that were mentioned as being "warm" sounding. Also, I soldered a Panasonic FM 2200uF / 25V electrolytic cap where the power supply is connected. Plus, I added the Ferrite beads to my speaker wires. The result is amazing! These new mods have completely changed this little amp. If the Elna Silmic II caps add warmth, then I guess I like "warm" I will try the Nichicon caps next.
What inductor/ferrite are you guys using? My Sure has a bit less noise with some old bead clamps from PE, but it utterly destroys the top end and more. I'm worried the 3116 could be like that. My Mini ClassDaudio has no top end, and similar looking inductors to the 3116 one-knob board.
Very glad to hear the bulk PSU cap and ferrite beads worked out for you, along with the Silmic mod. I need to give that last one a try. With the bulk PSU cap mod, I noticed a change from a thin, literal sound to a fuller sound with weightier lows, without sacrificing the balance between smoothness and detail on top, so there is definitely an increase in the current that is available instantaneously to the amp chip. Intuitively, I prefer the idea of preserving the smaller, possibly faster and lower-ESR 220uF caps in the power supply decoupling capacitor positions, and then letting them recharge from the bigger 2200 uF reservoir. It also makes the change to premium decoupling caps less expensive.
Each of the four wires, "+" and "-" from the speaker output screw terminal blocks get a Ferrite bead. So four beads total.
