0 Members and 2 Guests are viewing this topic. Read 620727 times.
Where can I find more info on the Weiner amp?
Rhing have you ever connected the Gmarsh Wiener to speakers that require a little higher inputsignal to the ampboard ?If you have those kind of speakers could you compare DC on speaker output Gmarsh Wiener to DC produced by Dugs mono boards or Sure3116 or any other tpa ampboard you have? I am curious what you'll see on your meter. I know what I see, I know I need to increase gainsetting Wiener to avoid higher inputlevels as a fix to keep DC output within what I would call hifi limits. Your Dug monoboards probably have the seperate avcc/pvcc setup too, so if your Dugs have equal DC on output as Wiener and Sure3116 has only a fraction of that amount like even YJblue, it might be avcc split connection causing the high dclevels playing music when inputsignal gets higher.(outputlevel matched with sinewave inputsignal, audiobah left output has -8mV DC, gmarsh Wiener same setting left output -218mV DC)
Rhing, What is the model number of your input transformers? Thanks.
Belden 8402 interconnect cables with Switchcraft 3502AAU RCA connectorsWestern Electric AIW 16ga speaker cables
RHING !Which transformers do you prefer ? I have used the Jensen Models but not the Cinemag. ThanksDwight
The Astron has a positive and negative terminal. The positive lead and negative lead from the board are connected to these terminals. The picture does not show this as I made the connections internally. The Astron is grounded via it's three prong wall plug.
The Astron is grounded. That's all one needs.
Is the ground from Astron attached to the amp module or there is no need to do that? If it is connected how do I go about connecting with just the external positive and negative connections.
Any idea of what size DC coaxial power connectors are needed to connect the Astron PSU to a Topping TP-31 ?
You could use something like this female barrel connector.Run wires from the Astron's terminals to it and plug into your Topping. My Topping TP21 uses a male input jack measuring 5.5mm x 2.5mm. http://www.ebay.com/itm/10-pcs-Male-Female-2-1x5-5mm-DC-Power-Plug-Jack-Adapter-Wire-Connector-for-CCTV-/111758608945?hash=item1a05550a31:g:gMUAAOSw3ydV48JR
cody69, did you use Duratex for the finish of your chassis? I finished my speakers in Duratex, here's a pic.
