0 Members and 1 Guest are viewing this topic. Read 620831 times.
20k is simply high. These amps would do well with a buffer. As is 20db gain with a 10k volume is about as good as you'll get for analog/attenuator control.
Nice work Randy. You must be a neurosurgeon to be able to modify the Audiobah board like that. Indeed, having high quality transformers like the Lundahl's on your DAC output and feeding the signal directly to the differential inputs of the TPA3116 amp IC is an ideal setup. I just received my DUG TPA3116 PBTL amp PCB's with the TPA3116 IC's mounted on them. I purchased these PBTL boards through the diyAudio.com Group Buy thread:http://www.diyaudio.com/forums/group-buys/257996-gb-tpa3116-8-pbtl-bare-pcb.htmlI can work with the other SMD's, but I didn't want to risk wasting my money or boards trying to mount the TPA3116 IC's myself. DUG will test them too for an additional charge.In the meantime, I've been assisting Roger Modjeski of Music Reference and RAM Tubeworks in setting up his audio engineering school and laboratory near Berkeley, CA. The other day I was at his lab, he lent me a prototype of a single 12AT7 dual triode line stage preamp. I've been listening to this preamp in my system, and I am really amazed with how well this works with my modified Yuan Jing TPA3116 blue amp. It is giving my Audio Research LS7 some serious competition. I am trying to talk Roger into making this preamp a DIY project to offer through the school. Roger is willing to test my modified TPA3116 amp in his lab and get measurements. Should be interesting what we measure.
I would also be curious how a tube audio legend like Roger likes the measurements of the 3116 with his ears.
Having a green Audiobah board with an Astron. Currently running it stock and it sounds great to me with the exception that it's not much bass at all. In fact, when connecting it to a sub via high-level there it's apparent that the low end is completely missing on some songs. I have connected it directly to a CD player, an ipad, and galaxy S4 via DAC. So what's the trick to get some more bass?The only way I can get some bass on songs is to connect to the pre-out on an old Pioneer Elite receiver and use the loudness function but that makes the sound muddy and comletely removes the magic.
Forgot to mention that when I moved cables around I managed to play the amp with no speaker load as well as only one speaker connected. To my surprise, I could hear soft music directly from the amp board itself!??? It sounded like when you stand next to someone playing music out of a pair of cheap headphones. Barely audible but I could distinguish the lyrics. So where is this coming from? Is this anything I need to worry about? Did not hear this from the Sure board.
