For those of us who cannot DIY, who makes complete amps with these new chips, just TBI?
Any recommendation on places to buy modular case. I used to have a link but lost it. Went to Radio Shack and looked at the project boxes and they were cheap plastic.
What size are the supply caps on the Sure TPA3110?
Question for folks who are more familiar with the modding. Why/When would you use a 35V power supply cap instead of the 25v. The reason for the question is that on the TDA7293 thread folks were talking about replacing the 25V cap with 35V, while in this thread folks are sticking with 25V. From the reading it seems that TDA7293 has ability to use 24V power supply which means that using 25V ps cap does not leave much room.Thx and Happy New Year
Wushuilu, figures I ordered a 3116 with the unwanted volume pot a few days ago without seeing this one.Ray
The TPA sweet spot is in the 12-21v range, so the 25v works fine. So far consensus is the TPA does not sound quite as good at 24v. Increasing voltage does potentially reduce ESR so if replacing PS caps, using higher voltage may be beneficial.
So replacing the 25V on the TPA board with 35V is ok to do. Similar question about 1500uf v/s 2200uf. I order both Panasonic FM and FR series caps yesterday in various combination, 25V (1500uf, 2200uf) and 35V (1500uf, 2200uf). Not sure which is better but the numbers on the FR looked better
For those looking to get more power and/or have less efficient speakers, there is a board available for 100w mono use as well. Usable down to 2ohms! This is probably the best looking board of the bunch in terms of build quality and layout. I was waiting to read some feedback on it before recommending. Mine has not arrived yet. Someone just posted very positive thoughts on it at diyaudio. It's a whopping $10 more. Breaking the bank at $30 http://www.ebay.com/itm/Amplifier-board-TPA3116-Class-D-2x50W-or-1x100W-Stereo-or-Full-PBTL-/161186376340?pt=US_Amplifier_Parts_Components&hash=item258774ea94
