0 Members and 1 Guest are viewing this topic. Read 60912 times.
We bought a Roku for $50. It has loads of free channels and private channels. Palladia, netflix etc.We then downloaded http://www.playon.tv/ for $49, lifetime. It has all the channels you find on cable, sattelite etc. With it's app playmark, we stream video and movies from the net to the Roku. Youtube, etc. any video basically.Our cost? 7.99 a month.
Sports was the only reason I hung on to Cable. I'm hoping I can get most of my sports fix through Aereo since I'm in the Atlanta market.
An HD antenna is cheap. Depends on the type of antenna and where your are - go to antennaweb.org and it will give you info. I get Baltimore and DC from where I am now with a big attic antenna and a preamp for it. titantv.com can also tell you what stations (cable or over-the-air) you can get from your area
My house is completely surrounded by tall trees
What else is needed to do this?Just a PC, or do I need a streaming compatible devise (Blueray / TV) that the RoKu hooks up to?I'd like to hook it up to my old CRT unit but it only has an analog screw on type of connector for cable or an antenna, no HDMI inputs, would that type of connector work?
Well the Roku connects to your TV. Most versions use HDMI connections, but some have composite connections. It would connect to your WiFi network to get streaming content.
I don't have WiFi but I have a fast internet connection. It's hard wired rather then wireless and I go thru a hard wired router, would that setup work with RoKu?Looks like I just found my answer. RoKu 3 is the only unit that works with Ethernet (hard wired connections) and works with HD TV's only so my old CRT unit won't work due to no HDMI inputs, bummer.
I forgot to add that part as well. I have ooma and pay like $4.00/month for the service. I have had that for a while now as well with no issues. I don't use the extra features as they are not needed as this phone has very light use.
