Suggestions for solid state Redbook DAC?
0 Members and 1 Guest are viewing this topic. Read 12684 times.
Re: Suggestions for solid state Redbook DAC?
« Reply #40 on: 9 Dec 2013, 02:19 pm »
mcgsxr and bk12,
You guys have hit on two of the DACs I'm most intrigued with (but I'd probably move up to the Emotiva Stealth DC-1), even though it's too solid state/cheap for some here.   :)
borism
« Reply #41 on: 9 Dec 2013, 02:53 pm »
The Tranquility DACs are very nice, even the original which I have seen sell used for less than $500.00.  No volume control and redbook only but excellent sound.
Best,
Ed
I want to second this recommendation. There is a Tranquility DAC in the AC classifieds for $350. That's a great deal on a great redbook DAC. I now have the SE version and continue to enjoy my ripped CD collection through MacMini-Itunes-PureMusic.
Boris
srb
« Reply #42 on: 9 Dec 2013, 02:58 pm »
I mentioned the Emotiva XDA-2 and DC-1 earlier.  If you buy a used XDA-1, make sure that it is not an early production model with an incorrectly programmed volume control.  I bought one of the first shipments of the XDA-1 and its volume control was incorrectly programmed with linear instead of logarithmic steps.  When directly connected to my power amp, this allowed for only 4 volume control settings between the quietest and loudest levels I would use, which of course, was too coarse! (26dB gain power amp with 89dB speakers)
Emotiva offered to reprogram the volume control if I returned it.  I ended up returning it for a refund as there were two other features that did not perform as described.  It was specified to have 24/192 USB but it was actually 16/48, and the dim control was supposed to cycle through an off position but did not).
Later shipments had the corrected logarithmic volume control, but if a seller of a used XDA-1 has not tried it direct to a power amp, they may not know if it is one of the later corrected units.
However it was a good sounding DAC, better sounding than the DAC in my Rotel receiver and equal to or possibly a bit better than my previous Stello DA-100 Signature.
This brings me to the DC-1.  I've not heard it, but it seems like a fantastic bargain at the still $499 sale price.  It uses two of the AD1955 DAC chips, has a good looking power supply and the NJR Muses 72320 is the same resistive ladder volume control chip used in the $16.5K Pass XP-30.  It also doesn't have the extra 10 always-lit landing strip lights of its little brother, which even at its dimmest setting had me thinking about a tinted acrylic front panel overlay.
« Reply #43 on: 9 Dec 2013, 10:16 pm »
Boris
Sorry, can't consider it as my computer sits too far away from the stereo to accommodate USB.  (I currently use a 35 foot optical, am I wrong?)
« Reply #44 on: 9 Dec 2013, 10:22 pm »
Yes.  The Emotiva DACs are quite intriguing.  Frankly for $110 more I'd go with the newer one, the XDA-2, fresh from the factory.  The Stealth DC-1 does seem quite impressive, but need to read some more reviews first.
