Treatment for room with beam in the middle
0 Members and 1 Guest are viewing this topic. Read 2351 times.
ctviggen
« on: 4 Aug 2004, 03:15 pm »
I have a beam running through my room, perpendicular to my speakers (if my speakers weren't towed in, that is).  I can definitely treat the "front side" (ie, the side facing the speakers) of the beam, but do I treat the "back side" of the beam?  What about the far wall, that also faces the speakers?  Also, do I load up treatments on the beam (and the area between the beam and the speakers) and only partially treat the rear portion of the room, or do I treat all portions of the room equally?
« Reply #1 on: 4 Aug 2004, 03:35 pm »
This is a good question as I have a panneled beam running left to right crossing my knees as I sit in the listening position.  My ceiling is 6.9 feet.  The beam hangs below about 6".
ctviggen
« Reply #2 on: 4 Aug 2004, 03:45 pm »
Mine's about a foot down from the ceiling.
8thnerve
Re: Treatment for room with beam in the middle
« Reply #3 on: 5 Aug 2004, 02:37 pm »
Quote from: ctviggen
Ideally, you want to treat both sides.  Especially if the beam is between your head and the speakers!  Otherwise, treat the side facing you and your speakers.
