Lets see your O.B. speakers....!
bladesmith
  • water quenching steel since 2001....
    • palmer knives
Re: Lets see your O.B. speakers....!
« Reply #400 on: 7 May 2019, 04:51 am »
RolandButcher
« Reply #401 on: 7 May 2019, 01:05 pm »
Sorry for the delay, I missed your post.  I've ordered 80/20 aluminum pieces for my next attempt.  They can be used to build whatever you can imagine without welding.
I'm looking forward to seeing what you come up with!
ricmon
« Reply #402 on: 7 May 2019, 04:04 pm »
Emrald Physic 2.4
Mijknarf
« Reply #403 on: 16 May 2019, 01:42 am »
Going on close to three years with this set up.  Man, I'd like to try something different, but I keep smiling when I listen.  Speakers are a design from Scott Faller (Lowther PM5A) and I added the Tone Tubby Alnico driver based on a Jon VerHallen design.  The SVS sub blends in to support under 80Hz
bladesmith
    • palmer knives
« Reply #404 on: 21 May 2019, 06:51 am »
That's a sweet setup... :popcorn:
aragon63
« Reply #405 on: 28 May 2019, 04:26 pm »
Drewan77
« Reply #406 on: 21 Jun 2019, 06:44 pm »
New member here but been with other forums & building Obs for many years. These are based loosely on the Pure Audio Project concept. Speakers are 3 way, measuring very flat down to 30hz with subs phase/time aligned at 50hz (it's a 5 way 2 channel system, two DEQX processors)
[/img]
« Reply #407 on: 22 Jun 2019, 10:32 am »
Welcome Drewan,
What woofers are these?
Drewan77
« Reply #408 on: 22 Jun 2019, 01:00 pm »
The woofers are Beyma 15" - 15LX60V2
« Reply #409 on: 22 Jun 2019, 04:27 pm »
Nice, QTS 0.44 is some low any reason to use this driver?
« Reply #410 on: 22 Jun 2019, 06:04 pm »
Beautiful work!  But how do you get a 5 way speaker?  I only see 4 drivers there.
Drewan77
« Reply #411 on: 23 Jun 2019, 03:41 am »
It's a 5 way system - 3 way speakers plus two subs. The master DEQX processor (HDP-5) handles the 3 OB stereo channels, the slave processor (HDP-3) manages the subs. All drivers including subs are calibrated using outdoor measurements and phase/time aligned across all frequencies.
The Beymas handle only 50-280hz. Transients, including bass frequencies are extremely dynamic & life like (much as other open baffle users would probably appreciate). The subs add a level of reality that is difficult to achieve with pure OB bass - something like a foot stomp within music sounds just like someone is walking softly in a different room above, more 'felt than heard'. I like (& need) that.
I voiced these speakers to sound somewhere between PAP Trio & Quintet 15s & having heard both types several times before/after building my own variants, I must say that I'm extremely pleased with the result.
The listening room is very heavily acoustically treated and therefore the only digital eq needed is a 34hz 3dB reduction @ a 3.8 Q to achieve in-room measurements as previously posted.
These speakers were finished early 2017 & were the 5th variant of OB I had produced. DEQX suits open baffle designs very well and I would class the last two types as sounding pretty exceptional. I doubt I will ever need to build anything else.
es20042
« Reply #412 on: 5 Jul 2019, 09:50 am »
Minimalist:
« Reply #413 on: 5 Jul 2019, 09:36 pm »
Welcome ES20042  :thumb:
These are the biggest baffles I have see.
JohnR
« Reply #414 on: 6 Jul 2019, 01:42 pm »
Awesome  :thumb: :thumb:
es20042
« Reply #415 on: 6 Jul 2019, 02:11 pm »
Thank you very much for the welcome! :)
For listening to music, yes; I love them a lot.
but for dimensions, no ...
Only 4.5 inches deep  :D
Fostex FE206E + Eminence Beta 15a +  Sica LP90.28/N92
Early B.
« Reply #416 on: 6 Jul 2019, 03:08 pm »
Minimalist:
I think you meant, "Maximalist."
Those are essentially in-wall speakers.
SubyC
« Reply #417 on: 12 Jul 2019, 11:10 am »
socrates35
« Reply #418 on: 13 Jul 2019, 10:25 pm »
My first OB project, for 2 watt 45 tube SET amp: Supravox 400exc - Zingali horn tweeter.
jeanper
« Reply #419 on: 14 Jul 2019, 06:21 pm »
These looked really interesting! I like the blue color. Are you happy with the sound?
