couple of questions about my 7BSST's
0 Members and 1 Guest are viewing this topic. Read 1390 times.
dukeofearl
« on: 23 Nov 2013, 06:55 pm »
Hi all , I have 2x 7bsst'S for my front L/R channels which i use the 12 v trigger from my processor , on power up sometimes the start up click (relay i presume) sort of double clicks or clicks   a few times , they always power up and work fine though . is this the start of a problem ??
Also I have just added a new processor to my system a primare SP 32 (which sounds excellent) I had them connected with RCA cables but i thought the XLR's would be a better option , so i changed the cables from  RCA's to XLR's and set the  switches on the back to balanced input and 2V gain  , i have noticed i need to turn the processor volume up a lot more to get the same level as with the RCA's ..
Can i use the gain on 1v with XLR cables ?
I would appreciate any advice ..
thanks .
  • The Demo is Everything!
    • http://www.bryston.com
Re: couple of questions about my 7BSST's
« Reply #1 on: 23 Nov 2013, 08:55 pm »
thanks .
Hi
Yes use the 1Volt settings.
james
dukeofearl
« Reply #2 on: 25 Nov 2013, 08:43 pm »
Thanks , set to 1 v and sounding great ..    James ,any thoughts on the relay double clicking now and again ?
« Reply #3 on: 25 Nov 2013, 09:51 pm »
Hi
It is just a function of the incoming power rush - no concerns at all.
james
dukeofearl
« Reply #4 on: 25 Nov 2013, 10:25 pm »
Thats great , thanks a lot .. :thumb:
