TAS5611
0 Members and 1 Guest are viewing this topic. Read 18793 times.
happyrabbit
TAS5611
« on: 22 Nov 2013, 02:20 pm »
I started this project out of curiosity.   I currently own a 2A3 Set Amp.
This design is a bit different from the TI reference layout.
I think it is a solid design.. :scratch:  I will have a couple boards next week.
Design Spec:
TI TPA3118D2
10watts @ 8ohms
20db gain (60Kohm input impedance)    No input buffer.
LC Filter designed for a 6ohm load.
14.8V 4S LiPo PACK  (133wh from BatterySpace)
INPUT CAPS : 2824 Film
LC FILTER : Bourns 2100 + 2824 Film
POWER CAPS :  10mm + 2220 Film
4 Layer 2oz CU FR4
75mmx75mmx30mm
Updated the Subject to Reflect the actual board...
« Last Edit: 23 Apr 2014, 09:02 pm by happyrabbit »
wushuliu
Re: TPA3118D2
« Reply #1 on: 22 Nov 2013, 04:33 pm »
Huge fan of these chips. They are outstanding amps. Look forward to your posts.
Would you be willing to sell one of your boards?
shadowlight
Re: TPA3118D2
« Reply #2 on: 22 Nov 2013, 08:55 pm »
Would be interested in a board also in case you decide to sell.  Need a winter project :)
randytsuch
Re: TPA3118D2
« Reply #3 on: 22 Nov 2013, 10:53 pm »
+1
What changes did you make from the reference design?
happyrabbit
Re: TPA3118D2
« Reply #4 on: 23 Nov 2013, 05:20 am »
Differences...   I am sure TI engineers are much smarter than me so please forgive the diyness...  :o
*  Switched Mosfets need the Lowest ESR + ESL possible.... This is very different from TI's recommendations...
*the power caps are placed next to the TPA3118D2.   Inductance is not your friend.
*I have pours on layers 1,3,4 tied to ground with a cap + ferrite bead in parallel. (layer 2 is gnd)
*The toroids are orientated parallel to the board.   The negative toroids are placed on the opposite side of the PCB.    Not sure this matters...  Mostly for packaging.
*I am concerned the LC Filter caps are not close enough to the battery gnd to be 100% effective.   I have no experience yet to know if this is an issue.  the 1st prototype will let me know.
*The TI reference design snubbers are closer to the outputs.       the 1st prototype will let me know
   :green:
Dwight
« Last Edit: 2 Dec 2013, 05:08 pm by happyrabbit »
shadowlight
Re: TPA3118D2
« Reply #5 on: 23 Nov 2013, 05:24 am »
still want a board if you help with all the newbie questions :lol:
happyrabbit
Re: TPA3118D2
« Reply #6 on: 24 Nov 2013, 09:51 pm »
A simple housing for the board and battery...  135mmx135mmx105mm.  The RCA's enter from the sides.  Speaker Terminals, on/off, and charger port in the rear.
Folsom
Re: TPA3118D2
« Reply #7 on: 24 Nov 2013, 10:50 pm »
I'd be into it if there were some taps for more power capacitors.
Also why are there inpit caps on the grounds ?
happyrabbit
Re: TPA3118D2
« Reply #8 on: 25 Nov 2013, 01:09 am »
My omega 3xrs speakers only need a couple watts.   I think I have enough capacitance.  Look up the Panasonic OS-CON.  These caps can carry ripple current.    The 10mm size is impressive.   The rubycon st provides the low esr and low esl to the mosfets .
 Differential inputs are biased to 3v.   Single ended inputs will still require both caps.
Dwight
happyrabbit
Re: TPA3118D2
« Reply #9 on: 25 Nov 2013, 10:33 pm »
Salis,
I agree.   After looking at other similar designs, I need to expand my horizons...just a bit.   :weights: :
 Ver 1.1   - Added a pair of 10mm capacitors to the back plane  + Bourns 2200 toroids +  Jupiter HT Input Coupling Caps
Thanks for the insight
Dwight
« Last Edit: 13 Dec 2013, 01:12 am by happyrabbit »
happyrabbit
Re: TPA3118
« Reply #10 on: 10 Dec 2013, 12:42 am »
UPS finally found my place  :green:
happyrabbit
Re: TPA3118
« Reply #11 on: 20 Dec 2013, 03:06 am »
 :green:
Folsom
Re: TPA3118
« Reply #12 on: 21 Dec 2013, 07:00 pm »
Well it looks great.
happyrabbit
Re: TPA3118
« Reply #13 on: 24 Jan 2014, 12:34 am »
Round 2...
Similar design goals but based on the TI TAS5611.  The main difference compared to the 3118/3116 is the bridges, gate drivers and the chip supply are separated from each other.
Plus this chip allows up to 32.5V.  The Input Gain is fixed @ 20db.
   The board dimensions are 110 x 110 (mm).
shadowlight
Re: TPA3118
« Reply #14 on: 24 Jan 2014, 02:43 am »
Did you drop the plans for 3118 board?
Folsom
Re: TPA3118
« Reply #15 on: 24 Jan 2014, 05:00 am »
You should let us know how they sound.
Have you looked through the 3110/3116 thread? Class D is weak without a large cap backing it up. It's key to them having what the big dogs do. It's fine to have 100-220uf as close as possible, but you won't class A like bass without serious capacitence.
You may be able to avoid other compromises once you accept that.
Overly large caps don't work, at least not cheaper ones at like 15k.
Folsom
Re: TPA3118
« Reply #16 on: 24 Jan 2014, 05:38 am »
C33-36 could be 470uf SMD FC's, and C57 should be like 8-10 1000uf's
Don't waste time with lm317 regulators either. Utterly ignore that stuff in data sheet. There's much better designs floating around DIY stuff.
happyrabbit
Re: TPA3118
« Reply #17 on: 24 Jan 2014, 04:20 pm »
Hi Shadowlight,
Depending on the outcome.... yes.   TAS5611 is a better chip.  YMMV
Salis,
I only need  3 to 4 watts. I have enough capacitors for my application.    Many of the current designs do not bypass 3116 supply correctly.       Switching Mosfets and large AL capacitors don't play well together.    You need some MLCC X7R or  Film @ the chip.   Low ESR / ESL @ the supply is a common design goal for any DC/DC converter ( plus low inductance returns).   I am using these from Rubycon to bypass the TAS5611 :
http://www.rubycon.co.jp/en/catalog/e_pdfs/pmlcap/e_st.pdf
35V 2220 10uf
Not using LM3117.   They are PI filters based on ferrite beads.   Its hard to tell just looking @ the posted images.  The pi filter cleans up the incoming switching noise plus contains the noise for each half bridge.
http://katalog.we-online.de/pbs/datasheet/74279224401.pdf
I am using  a TI  Linear LDO for the vdd and gate supply :
http://www.ti.com/lit/ds/symlink/tps7a4700.pdf
Dwight
« Last Edit: 24 Jan 2014, 11:25 pm by happyrabbit »
Folsom
Re: TPA3118
« Reply #18 on: 24 Jan 2014, 05:24 pm »
I don't see the purpose in accomplishing "enough" when what it is much better is avaliable. If you can ave high grade bass for a difference in sub $5, why not?
The caps I said could be replaced are larger than I said you could use as a replacement (Ti=1000uf , me=470uf) at the chip. Also I didn't recommend removing the smaller caps that can be film, that are on the same legs for power in. The multiple cap recommendation is for the power section of the amp, not next to the chip.
My C numbers are from datasheet, not your PCB, if there was any confusion.
happyrabbit
Re: TPA3118
« Reply #19 on: 26 Jan 2014, 05:02 pm »
Salis,
Here is your $5 upgrade  :green:
I actually like the layout.    Thanks for the motivation  :idea:
Dwight
Per 1/2 bridge : 16mm Main Caps + (2) 10mm Caps + (2) 2220 SMD  w/ 2200 Bourns
« Last Edit: 29 Jan 2014, 02:53 am by happyrabbit »
