0 Members and 1 Guest are viewing this topic. Read 82868 times.
I choose Muse ES caps for this next build, cheap enough it's cheaper to order 10 than 2! They are considered bass oriented (good for this amp) and know to be more transparent than many caps at higher prices, to naturally show of the extreme detail in this amp. My experience is they are pretty smooth to. It's going to be good; and docmented. Sometime next week..
Yea...both units I received had damaged pots. The "mummy" wrapping was so tight it bent both pots.On the bright side, my de-soldering skills are improving .
Along with the Black Gate N non-polar caps, I've had really good experience with the Elna Silmic II electrolytic caps in signal coupling applications. Nelson Pass recommended them when I met him at a Burning Amp Festival in San Francisco a few years ago.
I also like Silmics, and you can buy them from Digikey.
For folks who are totally removing the pot what are you replacing it with?
I Believe my intuition about using diodes as a filter for DC source may have been a good idea. I'm not testing with this amp since I am waiting on replacement, but my class D seems to be presenting an enhanced focus and harmonics. It would make since that a reduction of tiny AC flowing the wrong direction through a device only using forward current, would enhance accuracy of inlay or switching.
Question for the folks who understand the spec sheet. Do I need to make sure that the power volts listed on the PS is between 12V and 18V, with max of 4.5 amps? Assuming that if I go over 18V I am going to blow the amp but what happens if I go over 4.5amps? I am planning to run the amp with battery and just want o make sure that I purchase the correct battery.TIA
Hm, got a schematic?
Unfortunately SMPS's and many other power supplies we use tend to generate a tiny bit of AC
