Did you pull the diode?I'm just buggin you because at some point I think you might view it as a contender for your main amp (well depending on speakers)
Any chance the speaker cables may have shorted? It can easily happen when strictly relying on those terminal blocks for bare wire connections.
The diode is the next thing to go. Somehow I doubt if it is going to replace my Moscode 401HR. I need those 200 wpc to control the back EMF on my LS9 speakers. Nearly everyone that owns them has come to the same conclusion. Oh, the orange drops are decent polypropylenes.
Nice LS9 linear arrays with ribbon tweeters. Dannie Richie is a great, and under-appreciated speaker designer. I was at that RMAF, but missed hearing the LS9's, there was so much to see and hear. I wish I did, because linear arrays are great speakers when done right. It's the reason why so many excellent pro audio set-ups use them.The TDA7297 will never give you enough current to power those speakers. I'd be interested in how good the little amp sounds with those "mod" DA geodesic speakers.
It's not the wima cap. It has nothing to do with it, BUT you should replace it with stock one. The Wima is way too big. It might lower the gain of the amplifier significantly.Your incoming wires for signal are connected to nothing. Please look at this, and rewire to these holes for R(ight) , L(eft), and G(round)
Salis,Will rewire the left and right with ground. What am I suppose to do for the other 4 holes which are left of the R/L connection? I am also getting a replacement volume pot and wiring changes do I need to make to get it working with the new pot.
Actually, your wiring looks good as is, as long as you wire the new pot to the the six holes where the old pot was pulled. If you follow the traces on the bottom of the board, you will see that there are connections from the input wires you installed and the holes for the removed pot. The signal passes thru the pot to the coupling caps/amp. That's why you are getting no sound.Hope that helps.Mike
Thanks Mike. I guess I better order the new pot soon.
Clark, if I sent you 4 Nichicon caps would you give them a go? Also I wonder how a lithium battery that's lower impedence would sound.I am meaning to put a B1 buffer in front of this amp. It seems sensitive to impedence matching since it's leading and trailing detail goes up with volume (hence some imaging and timbre).
