FS: Cary Audio SLP 05 Mint Condition - One Month Old
0 Members and 1 Guest are viewing this topic. Read 1438 times.
achappy
Asking Price: $5300.00
New    Price: $8500.00
Sellers Zip Code: 33701
I am selling a mint condition SLP 05. I bought it on 13 October 2013, and received it on 18 October 2013, directly from Cary Audio Design LLC in Apex, North Carolina.  It is in "as new" condition. I have checked all inputs and outputs and found no problems.  I estimate that it has been used for less than 100 hours.  I'm selling all of my tube gear as I'm switching to ss gear to drive my new electrostatic speakers including a room and speaker correction solid-state preamplifier.
Box 1 of 2: SLP 05 Preamplifier 23 lbs. 22"x18"x9" (LxWxH)
Box 2 of 2: Power Supply 25 lbs. 22"x18"x9" (LxWxH)
If using PayPal, add 3% to the purchase price.
Thanks for looking.
Great Reviews:
http://www.positive-feedback.com/Issue54/slp05.htm
http://www.positive-feedback.com/Issue25/cary_slp05.htm
http://www.theabsolutesound.com/articles/cary-audio-slp-05-linestage-preamplifier-cad-211-fe-monoblock-amplifiers-tas-205-1/
http://www.stereophile.com/tubepreamps/906cary/index.html
http://hometheaterreview.com/cary-audio-slp-05-preamplifier-reviewed/
http://www.6moons.com/audioreviews/roadtour10/roadtour10.html
and Rewards:
2013 The "Editors' Choice Award" from The Absolute Sound
2012 The "Editors' Choice Award" from The Absolute Sound
2011 The "Editor's Choice Award" from The Absolute Sound
2011 "The PFO Writers' Choice Award" from John Brazier
2010 "Product of the Year" from The Absolute Sound
and the SLP 05 is a "Stereophile Recommended Component"
SPECIFICATIONS
Operating the SLP 05 Preamplifier is a simple procedure since each unit is designed for long-term stability in virtually any home operating situation. However, if the unit is operated outside the parameters outlined in this owner’s manual, damage may occur. Please read this manual carefully before operating your new SLP 05 Preamplifier.
GENERAL SPECIFICATIONS
Circuit Design Class A Triode Vacuum Tube Preamplifier Design
Output Voltage 2 Volts rated, 12 Volts maximum
Overall Gain 17dB Single-Ended RCA
24dB Balanced Operation
Rated Distortion 0.03 % THD
Noise and Hum -90 dB below full output
Input Impedance 50,000 Ohms - RCA
100,000 Ohms - XLR
Output Impedance 400 Ohms
Frequency Response 5 Hz to 250,000 Hz
Vacuum Tubes 8 ea - 6SN7 tubes for the balanced, headphone and gain stages
1 ea - 5AR4 Rectifier Tube in Power Supply
Power Transformers R Core 200% Duty Cycle
Resistors 1% Metal Film
Capacitors Polystyrene, Film and Foil
Power Supply Capacitors 2 ea – 560 μF 400 VDC
AC Cord 3 Conductor, Detachable
AC Power Requirements 117 or 234 VAC 50 or 60 Hz
Consumption 75 Watts – Operation, 25 Watts - Standby
Warm-Up Time 3 Minutes
Break-In Time 100 Hours of Playing Time
Chassis Finish Silver Anodized Aluminum Faceplate Std, Black Optional
Jaguar® Anthracite Black Finish on Chassis
Net Weight 16 lbs. – Preamplifier
19 lbs. – External Power Supply
Dimensions 6.25” H x 17” W x 12” D – Preamplifier
4.5” H x 17” W x 12” D – Power Supply
About 10.5” H Stacked Together
FEATURES
Features of the SLP 05 include:
• Fully Balanced Design
• Motorized remote volume control and muting
• One (1) Cinema Bypass
• One (1) tape monitor loop (RCA Connections)
• Two (2) XLR balanced stereo inputs
• Three (3) RCA stereo inputs
• One (1) XLR balanced preamplifier output
• One (1) RCA preamplifier output
The matching ‘chassis size’ external power supply comes with 5AR4 vacuum tube voltage rectification and has two front panel meters for the circuit voltage and the current bias readings. The SLP 05 has a timer warm up circuit that allows safe use with “rapid turn on” solid state power amplifiers. The headphone power amplifier, using two 6SN7 octal vacuum tubes, is coupled through audio transformers to produce 1/2 watt per channel to drive your favorite high quality headphones.
« Last Edit: 19 Nov 2013, 12:38 am by achappy »
