Factory-finished Neotech interconnect Blowout!
Jeff
  • Test...
    • Sonic Craft, Inc.
« on: 11 Nov 2013, 12:39 am »
*limited to stocking inventory*
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-5004 has a large cross-section stranded UP-OFC center conductor, low-loss foamed Polyethylene dielectric, and high-density UP-OFC braided shield. The NEI-5004 is terminated with Neotech's DG-203 RCA connectors.
The NEI-5004 0.5 meter pair is $20.50, 1m pair is $22, 1.5m pair is $23.50, and a 2m pair is $25!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-5003 has a stranded UP-OFC center conductor, PE insulation, low-loss foamed Polyethylene, and UP-OFC braid/conductive PVC shield. The NEI-5003 is terminated with Neotech's DG-203 RCA connectors.
The NEI-5003 0.5 meter pair is $21, 1m pair is $22.50, 1.5m pair is $24, and a 2m pair is $25.50!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-5002 has a stranded UP-OFC center conductor, low-loss foamed Polyethylene dielectric, and UP-OFC braid with AL-Mylar screen foil shield. The NEI-5002 is terminated with Neotech's DG-203 RCA connectors.
The NEI-5002 1m pair is $23, and a 1.5m pair is $24.50!
Save over 50% on this excellent factory terminated interconnect!*The Neotech NEI-5001 has a stranded UP-OFC center conductor, low-loss foamed Polyethylene dielectric, and high-density double layer UP-OFC braided shield.*The NEI-5001 is terminated with Neotech's DG-203 (even though the center pic shows a DG-202) RCA connectors.*
The NEI-5001 0.5 meter pair is $22.50, 1m pair is $24.50, 1.5m pair is $26.50, and a 2m pair is $28.50!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-4002 is a balanced Silver plated OFC conductor, PE insulation, low-loss foamed Polyethylene dielectric, and double shield via Tinned OFC braid/AL-Mylar foil shield. The NEI-4002 is terminated with Neotech's DG-202 RCA connectors.
The NEI-4002 0.5 meter pair is $32.50, 1m pair is $37.50, 1.5m pair is $42.50, 2m pair is $47.50, and a 3m pair is $57.50!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-4001 is a balanced Silver plated OFC 4 conductor design, foamed PE insulation, low-loss foamed Polyethylene dielectric, and double shield via Tinned OFC braid/AL-Mylar foil shield. The NEI-4001 is terminated with Neotech's DG-202 RCA connectors.
The NEI-4001 0.5 meter pair is $32.50, 1m pair is $37.50, 1.5m pair is $42.50, 2m pair is $47.50, and a 3m pair is $57.50!
Save over 50% on this excellent factory terminated interconnect!  The Neotech NEI-3005 uses a UP-OCC stranded center conductor, PE insulation, low-loss foamed Polyethylene dielectric, and triple shielding via doubled OFC braid/AL-Mylar screen foil. The NEI-3005 is terminated with Neotech's DG-202 RCA connectors.
The NEI-3005 0.5 meter pair is $37.50, 1m pair is $42.50, 1.5m pair is $47.50, 2m pair is $52.50, and a 3m pair is $62.50!
Save over 50% on this excellent factory terminated interconnect!  The Neotech NEI-3004 is a balanced/stranded UP-OCC conductor, PE insulation, low-loss foamed Polyethylene dielectric, and is double shielded via a OFC braid/AL-Mylar.
The NEI-3004 is terminated with Neotech's DG-202 RCA connectors. The NEI-3004 2 meter pair is SOLD OUT, and a 3m pair is SOLD OUT!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-3003 UP-OCC stranded center conductor, PE insulation, low-loss foamed Polyethylene dielectric, and double shielding via doubled AL-Mylar screen/UP-OCC braid. The NEI-3003 is terminated with Neotech's DG-202 RCA connectors.
The NEI-3003 0.5 meter pair is SOLD OUT, 1m pair is SOLD OUT, 1.5m pair is SOLD OUT, 2m pair is $87.50, and a 3m pair is SOLD OUT!
« Last Edit: 21 Aug 2014, 06:24 am by Jeff »
cardani
Re: Factory-finished Neotech interconnect Blowout!
« Reply #1 on: 16 Mar 2018, 01:44 pm »
Hi do you still have available the The NEI-3005 0.5 meter pair interconnects? thank you, Carlos
