Technics SL1210 Mk2
0 Members and 1 Guest are viewing this topic. Read 1046 times.
jmartinbaugh
Technics SL1210 Mk2
« on: 10 Nov 2013, 02:32 pm »
Hi
Can anybody offer advice please.  I am fitting an external power regulator a Paul Hynes PR3iTD and have replaced the Electrolytic Capacitors on the motor control board with Panasonic FC. But I have found that the target light has blown, I have seen on the web that you can replace the bulb with a LED by using a 5 volt T020 voltage regulator to drop the voltage. Would this cause any extra noise to the circuit? if so can anybody suggest an alternative.
Many thanks
