0 Members and 1 Guest are viewing this topic. Read 10651 times.
Seems these gauges you mention will offer a more friendly impedance to the amp, but I could not use it myself.I understand the option of these manufacturers as a thinner wire have less resistence and less cost.
Hi FULLRANGEMAN and all Audio Circle members.I don't know about you, but me, with my technical knowledge: The thinner the wire , the more impedance Ohms you have.The larger in diameter the wire is, the less resistance you have.Am I right ?Guy 13
I think internal wiring and connectors as cheap spice.They are there just for convenience.
Guy13, yes. FRM, The quality of the copper effects the sound quality but not the overall resistance of the wire. If you want, it is not difficult to calculate the voltage and amperage going to your speakers... with a small tube amp and efficient speakers it's not much. V = IR > P = V^2/R, V=sqrt(PR)P = IV So... say I'm running all out 5 watts into my 8 ohm Super 3s... voltage is ~6.3 volts. I = V/R so amperage = .7875 amps. Voltage drop on a 10' run of speaker cable will be about 2.5% for 20 gauge wire... it'll be fine
Hi all Audio Circle members.Try this link, it will make your life easier when trying to calculate wire power loss.http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swfQuality of wire material (Silver vs copper) and wire loss are very different.Guy 13
IMO... silver is pretty bad unless it's 4N or better purity. Duelund and Neotech are both 5N+ purity and they sound much better than normal 4N silver wire. Silver is a better conductor but only by a few percent, it's not a huge difference. If you have a run of speaker cable and different wiring inside the speaker cabinet, the resultant sound will be a mix of the two roughly in proportion to how much is used. beo, you might want to try UPOCC copper as well, it's much better than normal copper and much cheaper than silver. I think it's the best value for the money in speaker cables.
Yes, I'm saving up for the OCC style cables - I believe it has merit to it's design and would like to try your cables when I am ready to purchase. I read an interesting paper from Tempo Electric on solid core silver cabling and found it interesting as well - however prices can get stupid for 10 and 12 gauge solid core cables (especially because I need 10 feet)!
